Question about Whirlpool Calypso GVW9959K Top Load Washer
Black Stains on my whites
We are getting black stains on our whites - The Whirlpool Calypso we have is 6 years old. Can anyone tell me what may be causing the problem. I looked inside the tub and nothing appears to be obvious that may be causing this. Looks like others are having the samae problem. We haven't had any clothes get stuck. Help!!!!!!
  • Gary Davd
    Gary Davd May 11, 2010
    you might have a leaking seal under the Nutator
    President:
  • 1,314 Answers
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Posted on Feb 14, 2008
Calypso stains load
Hi there
I wonder why "dark streaks" on white towels. I presume that you have made sure that there is no dirt flying around in the machine.
Try to let the machine go a circle -without any washing in it- just to see if the water takes color. There are also in the shops washing powder
that remove stains of different types.
Also powder for "only whites"
good luck
Kolbrun
Apr 23, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Get streaky black stains on white fabricks that can't be removed. What could be causing this? Did the (bleach & soap) cleaning routine covered in the manual. Washer is 7 years old. Please help if...
I am experiencing the same problem and someone just told me it is a leaky transmission and some models have replaceable seals otherwise you would have to replace the entire transmission. I'm not sure what would be more cost effective if you can't replace the seals. Good Luck!
Jun 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Black grease stains on cloths, grease is coming out from one area in the drum. Whirlpool Calypso-6 years old. Is it worth repairing ?
Machine life is depends on the cabinet condition if the cabinet condition is good means you can service the machine it will be useful otherwise it is better go for exchange
If cabinet is good condition means you can use it for few more years also
Jan 08, 2010 | Washing Machines
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Black grease stains on clothes
trasmission top seal is bad
oil out means water in
Jun 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Black stains on white table cloth
Hi! topjdog
I hope you have been running the monthly cleaning cycle. This includes cleaning the front gasket.
InMrFixIt
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
Rust Stains
you will probaly need serviceman..the parts that control the plate in the bottom are starting to corrode and accumilate gunk that is coming back off on clothes replacing them only fix also may ck the recirculating pipe on right rear side of tub gunk can accumilate there also
Jul 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer black streaks
to all that are having a problem with these calypso washers... if you have paid for a repair then you need to check out the lawsuit... calypsosettlement.com and see if it applies to you.
but if you are getting a mark or a residue on your clothes, then look at the inner wash plate gasket, where it meets with the outer stainless steel tub. if there is a gap between the gasket and the tub then thats where the marks are coming from.
it happens alot and thats not covered by the settlement, but its not too bad to replace the inner wash plate. you need to remove the cabinet, then the tub cover and the innerwash plate dome. then 6 screws and the cover will come off.
replacing the inner wash plate will solve the stains and get you a few more years of use until you have to buy a new washer as more items may fail.
Apr 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso GVW9959Q - Black stains on whites
discoloration.
RESOLUTION:
Feb 14, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
275 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
