Question about Philips 27PT6441 27" TV
Phillips 29" TV
My TV shuts off automatically after sometime. First the picture get squeezed and when whacked on tv it get turns to normal picture. how ever after sometime even whacking doesnt help and the picture and sound is completely gone.
  • 579 Answers
Sounds like it has an intermittant connection somewhere which is very common now a days due to the lead-free solder all the makers went to. Resolder everything that looks suspicious, especially the bigger components. It could also be a failure of the flyback transformer though which often times fail like this.
Hope Ya Fix It.
Posted on Feb 13, 2008
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV shuts off within 5 seconds of turning on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
Protron PLTV-32CM LCD no picture
This TV set is still under the warranty and it seems proton has no local service available to you. I know its to late to tell you this but anytime you purchase a set, ask first and see if there is a service local to you. Ok enough of that noise.. I would go back to the store where it was purchaced and ask them if they know of any local shops that handle the warranty repairs.. If you want to pay for the repair, and that will most likly be alot for a flat panel set, You will have to call back proton and ask about the shipping cost and whos responsible for that.
Sep 30, 2006 | Protron PLTV-32 Television
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Phillips tv
What does the screen looks like just before it shutsdown?
Sep 06, 2006 | Panasonic TC-29P22R 29" TV
Picture stretched or "squeezed" inward from sides - black section on side.
Your problem is a common one and wht tells me this is when you wack the set. Theres a couple of coils that look like small towers that stand up and would have an L4#### number of some sort. They would be located toward the right side in the middle.. BUT for cryin out loud BE CAREFULL please!!!theres thousands of volts in a tv set. Oh and NO for sure this is not a Picture tube problem Good Luck
May 27, 2006 | RCA 27F530T 27" TV
Philips 27PT6441 27" TV Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
