Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Rinnai monitor heater 1004F
The heater is flashing the number 12. It turns on, then the heat turns on, but then it stops and blows cool air...what do I do????
  • 2 more comments
  • aztecapr1 Feb 13, 2008
    I havent been able to use the link I was given for information on why my heater isnt working. I rent a large farmhouse and it is the only source of heat that my young children and I have. We are in the middle of a big snow storm and we are very cold. Can anyone out there please help me????????
    I TRIED THE LINK ( http://www.rinnai.us/Rinnai.aspx/FileLib ) FOR A SOLUTION TO MY PROBLEM BUT TO NO AVAIL. THE WEBSITE IS UNAVAILABLE OR HAS BEEN CHANGED. DO YOU HAVE ANY OTHER IDEAS?
  • aztecapr1 Feb 14, 2008
    If the heater is flashing #12, check to make sure nothing is in front of the outside vent. I went out to check mine and there was no snow or ice around it, BUT there was a snow bank 1/2 foot IN FRONT OF IT. I shoveled the bank to below the vent level and the heater began working again.
  • Gerardo Toyloy
    Gerardo Toyloy Mar 29, 2014
    yes it work thank you, code 12 come out when exhaust pipe in the outside is block.
  • 549 Answers
Http://www.rinnai.us/Rinnai.aspx/FileLib
hope this helps
Posted on Feb 13, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 14, 2008
    code 12 is low gas pressure, or that the flame sensors are not picking up a flame, try removing the flame rods, in a rinnai infinity when you pull the cover off they are right in the middle, you can use a file to clean any carbon etc off,
    Actually the Rinnai 1004 has an E2prom chip in it that should hold your last setting. If there is a power outage longer than 12 hours, you may have to reset it
    Try and unplug you heater for a few hours and see if the settings stayed. Extend the durration until you find the point of no return. Check all the error codes stored in the unit by holding down on the Economy button as well as the up and down arrows all at the same time. Because you will need both hands to do this, get a friend to write them down as they are displayed.
    The rinnai website is not abvailable.
    Try these things
    aotherwise call 911
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
The fan stopped blowing for the air conditioning and heating
Check the fuses, or the whole knob assembly went bad.
Oct 15, 2017 | 2005 Nissan Sentra
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
Jan 29, 2012 | 2001 Daewoo Nubira
Heater core is working properly but car will not blow hot air only cold air i am thinking the flapper that controls hot \ cold is stuck in the cold air position
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
Jan 25, 2012 | 2001 Buick LeSabre
Honeywell Thermostat RTH110B
It probably has stopped outdoor unit and the blinking is to be done when working anamoni.afto heating and not to bring in cold air flashes the LIGHT as long heated air into the condenser.
Nov 01, 2011 | Honeywell Electronic Programmable...
I have got an electric fire Place that blows out hot air, well after about 5 mins it stops blowing out hot air and it blows out cold air, can any one help me fix it?
More than likely, the heater element is overheating and the overload switch is turning it off. It could just be a case that the heating element needs cleaning. As they do become clogged with dust and lint, because they take in cool air at floor level, heat it and send it back out. You didn't mention who the manufacturer of your electric fireplace is, but they all work just about the same way (badly, most of the time). Turn OFF the Master On/Off Switch, unplug the fireplace from the wall and leave unplugged for 12 to 15 minutes. Now, would be a good time to clean the interior, if you want to under take it. Plug the heater back in and turn the Master On/Off switch to the On position. Turn ON and set the heater control. If it returns to normal operation, the problem is solved. If the unit continues to have to be reset (if it's a Dimplex) turn the Master Switch Off, unplug the unit and contact Dimplex USA, Technical Service at 888-346-7539 for more information.
Hope this helps solve the problem.
Mar 17, 2011 | Heating & Cooling
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
1,199 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
