Question about Acer Aspire 5500 5570-2609 Laptop
Installing ram the acer aspire 5570-2758 does support up to 4gb of ram ... i recently purchased a 2x2g from new egg.heres the link to the product: http://www.newegg.com/Product/Product.aspx?Item=N82E16820141342 When i installed both of the 2 gb sticks into the 2 slots and turned my computer on, it turned on, but nothing happened-the screen did not turn on.. if i install one of the 2gb sticks with either of my old 1gb sticks...same thing happens BUT if i install one of the 2gb sticks and leave the other slot empty, my computer turns on and recognizes 2gb of ram..and functions fine..please help me and help me figure out why my computer does not work when installed with 4gb of ram
  • 1 more comment
  • jeff koung Feb 13, 2008
    what would be considered low density? im a newbie at ram..and i guess my question is..in allthe number provided on the type of ram i have...what number do i want to be lower? so i know what to buy
    thanks sirhanz,....so just wondering..since im a noob to ram...and different types of ram....in all the numbers that come with ram. like..200 pinddr2 so-dimm ddr2 667 (pc2 5400)...which number do i wnt to be lower? i guess..how do i distinguish low density ram from regular ram
    lol oops double post..dint know the first one went through
  • 145 Answers
It will support up to 4 gbs of ram but they both have to be low density, the unit can not go more then 2gb with high density ram.
Posted on Feb 13, 2008
Needed Drivers For Aspire ES1-512 Laptop FOR WINDOWS 7 32 BIT
If Acer never made it compatible with windows 7 in the first place you are out of luck. They made it to work with 8, so they had no reason to support win7, therefore it doesnt and you should.... install 10! or 8.1
Jul 24, 2015 | Acer Aspire Computers & Internet
I need to replace mother board for Acer Aspire T-650 PC. please advise me which is the suitable mother board
Hello
If your going to replace the motherboard here is a link to your pc specs.
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT650/AspireT650sp2.shtml
You can also upgrade if you want.To a intel dual core processor and chipset.You will need new memory.
Check out www.new egg.com or pc direct.
If you want an exact replacement then you may need to contact Aspire.
May 17, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
How do you install 2 gb memory in acer aspire one D255
vtxgreg, I typed out a lengthy solution to replace Ram Memory in an Acer Aspire One D255, but after looking through it once finished, I thought this to be the better solution.
1) Video of how to remove the Keyboard,
http://www.youtube.com/watch?v=FoTwln2SyQ4
[ NOTE*
I advise against using a utility knife blade. That's just Dumb! Use a small flat tipped Jewelers screwdriver.
I also advise buying, and wearing an ESD wrist strap. Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
(You probably won't even see it, or feel it)
Connect the alligator clip to a good ground source.
{I connect to the metal frame of an empty desktop computer case}
Price for an ESD wrist strap averages around $3 to $6.
Here is an example of one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16899339002&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Tools+-+Network+/+PC+Service+/+Acc.-_-Cables+Unlimited-_-99339002
(You can get them cheaper as I stated above)
2) Video of how to replace Ram Memory in an Acer Aspire One,
http://www.djody.com/acer-aspire-one-memory-upgrading/
Use a multi-compartment container for the various screws you will remove.
mark each compartment for the area the screws come out of.
A LOT of the screws look VERY similar to others, but they are NOT.
Do Not mix them up!
If a multi-compartment container is not available, you can use a clean egg carton in a pinch. Mark each egg holder.
Nov 28, 2010 | Acer Computers & Internet
ACER Aspire 4520 video card problem
when you play the game turn your graphics down and it will play better like 1260x800 turn it down to 400x 600
Nov 01, 2009 | Acer Aspire 4520-5582 Notebook
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
How to Upgrade to max RAM
The Acer Aspire One can be upgraded to a total RAM of 2Gigs. This will allow for you to upgrade to Windows XP Pro and also to Microsoft Office 2003 as there is no version of Office Professional. If you would like more specifics on your particular model, please look here. http://www.laptopmag.com/review/laptops/acer-aspire-one-10-inch.aspx?page=3
Upgrading RAM is a fairly simple process. As this is a fairly compact laptop in design, you will have to upgrade to a new 2Gig RAM module and basically discard (or sell) the one you end up removing. In order to find out the type of RAM you'll need, remove the cover as show in the picture and the info for the existing RAM should be written on it.
Apr 19, 2009 | Computers & Internet
Apparent conflict between my wireless adapter and RAM
have you tried looking for an updated bios version for your motherboard?
Jan 05, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
