Question about Hamilton Beach Stay or Go 45235G 8-Cup Coffee Maker
Coffee not hot enough
Stay Or Go Model 45235G. Only made 3 pots of coffee. First two were great. Last one was warm, not hot. Tried again, Still only warm.
  • Decafman Feb 19, 2008
    Thank you for trying. So far, Hamilton Beach has not responded to my help request because I misplaced my receipt. I am still hoping they will consider concerns.
  • 552 Answers
Http://www.amazon.com/Hamilton-Beach-Coffee-Thermal-Carafe/dp/B0000W4N0G
This page has alot of info about this coffee maker.
There is customer feedback here too.
It may answer your question.
Posted on Feb 13, 2008
Our brand new Cuisinart model DCC-1150 10 cup coffee maker with the stainless steel thermal carafe makes a great tasting cup of coffee but the coffee isn't piping hot when first made and the carafe doesn't...
I am having the same problem, along with the coffee leaking onto the counter. I think this coffee pot is just defective. If not, I wish someone would come up with an answer.
Oct 21, 2010 | Cuisinart (DCC1150) 10Cup Coffee Maker
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Water not hot on Bunn coffee maker
Check the Hi-limit thermostat on top of the tank, then the pressure stat setting and then the inline fuse and then elements.
Mar 03, 2010 | Bunn CWTF20-3 Automatic Coffee Brewer -...
Coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
May 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Don't understand how it works
This coffee maker has a hot water reservoir that heats and stores hot water so it can brew coffee faster. Once you fill the reservoir by pouring a potful of cold water into the top, you can turn on the switch at the side of the unit and in about 10 minutes the water in the reservoir will be hot. I usually leave this switch turned on to keep the water in the reservoir hot. The front switch turns on the pot warmer at the front of the unit, so it should be turned off unless you are making coffee or keeping a pot warm. To make a fresh pot, put a filter and ground coffee in the removable filter basket, slide the basket into the unit, place an empty carafe on the warming burner and using a separate container pour fresh water into the filler at the top of the unit. The fresh water displaces the hot water in the reservoir and voila, the coffee carafe starts to fill. The amount of fresh water you added is the amount of coffee you will end up with, less a little bit that might have evaporated if you only make coffee every morning or less often. Most units have a plunger under the filler lid that keeps the fresh water from going in to the hot water reservoir until you close the lid, so close it after pouring in the water. Also, turn off the front switch if the carafe is getting low or empty, as it can get hot enough to crack the carafe. If you're not going to be using the coffee maker for several days, turn off the side switch or unplug the unit to save energy and reduce evaporation from the reservoir. I love mine. It makes great coffee and is much quicker than the drip type.
Apr 14, 2009 | Bunn NHB Coffee Maker
The carafe dribbles coffee when pouring.
This has been a problem with many carafes. I tried something I saw on a home show once, and it works, but... it may seem weird and undesirable. Unless you pour just the tiniest stream, the liquid wants to stay with the pot, you see. It will be attracted along the spout back down the pot, causing the dribble.
Put just a tiniest smear of shortening or oil on the pouring lip, and the problem will instantly disappear.
You've already guessed the undesirable part of this, right? Yep. It doesn't last for long because the hot water cuts through the film after a few pours. And, who wants Crisco in their coffee?
I didn't notice anything different with my coffee when I tried it. Probably not enough grease to make that much difference.
But the "back-drip" ended pronto.
Joe Java Lover
Jan 17, 2009 | Hamilton Beach Stay or Go 45238 10-Cup...
Thermal carafe has liquid in cavity and coffee does not stay hot
Call Cuisinart and see if they consider it an in-warranty issue (it has a 3-year warranty). If it were just the liquid issue that would be one thing, but since it's not keeping the coffee hot, then you have a hidden crack somewhere. Mine has the sloshy liquid issue, but I just live with it since it still keeps the heat inside. Otherwise, it's been a great coffeemaker that has lasted for over 6 years. As far as the coffee spilling everywhere - I would switch to paper filters (don't use the paper in conjunction with the gold tone filter). The filter basket door latch may be worn - as many problems as you're having, this may be a warranty issue that Cuisinart can solve.
Dec 18, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Hamilton Beach Stay or go Coffee Machine
I finally got in touch with the Hamilton Beach (1-800-851-8900 between 8:30-4:00 EST) and found out that Model 45235G replacement carafe is available for order from them for $25.98 (S/H included) plus state sales tax.
Sep 03, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
8-cup Farberware electric coffee maker
Hi, I just posted this for the FCP412 model: here it goes again.
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here: http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck. -david
Oct 09, 2007 | Faberware FCP280 Coffee Maker
Hamilton Beach Stay or Go  45235G 8-Cup Coffee Maker Logo
340 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
