Question about Hunter 33202 Humidifier
Noise The 33202 ran fine for the first two weeks. Now, when it runs (at any speed) it sounds like water running (like from a faucet into a sink with water). It is not the girgling sound from the tank.
  • mawd706 Jan 11, 2009
    i have that issue too, but also have a loud motor issue. the motor sounds like it is dying!.ony use two weeks.
I do appreciate your thorough and clearly written suggestion. However, I am familiar with the "workings" of this (and past) Hunter humidifiers. I tried your suggestions before I wrote that post. What I can't figure out is why the humidifier is quiet some nights and others it is that cascading waterfall sound. Thanks again!
Posted on Feb 27, 2008
The Hunter 33202 uses a recirculating pump to keep the aluminum mesh wicks (filters) wet. There is a vinyl hose which runs from the pump outlet to the top of the main unit (you will need to lift the main unit off the base to see any of this, much less do anything to fix the noise). The top of the hose meets the diffuser, which has several small holes to drain into that V-shaped double trough (located directly above the two wicks) which has larger drain holes on either side. If any of the holes in the diffuser or the trough become clogged, the other holes will tend to release a higher volume of water, which could lead to that running faucet sound. The clogs are easy to dislodge-- they're usually mineral deposits from the water. Another likely cause is the filters becoming clogged from dust that's being sucked in from the fan. Easy fix, also-- remove the wicks every week or so and thoroughly rinse them under running water.
My diffuser will not mist. The lights are on and it is running fine otherwise. What is the problem?
Did you use distilled water ?
Ours called for distilled water to work correctly, we used tap water and it worked for the first few times. then started making noise and then stopped.
Started using RO water, (like distilled) and started working again.
Apr 07, 2015 | Humidifiers
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
I have 2 of these humidifiers and neither seems to be dispensing moisture into the air. The fans work fine and the filters are new. I am using regular tap water and have placed them in a room and ran...
If your "tap water" is from a well, the humidifier may be clogged with mineral scale. Even if it is not well water, your municipal source may have a high mineral content.
Using a 50/50 solution of White Vinegar and water run through the system will usually clean the mineral scale out. In the future, I would recommend that you use Bottled Distilled Water. You can buy it by the gallon, inexpensively at grocery stores or pharmacies.
Feb 24, 2011 | Holmes Products HLS1200-U 1 Gallon...
I have a Carrier humidifier model #HUMCCLBP2217-A. It appears to be working, but every time it shuts off it emits a very loud "thump". The noise is loud enough to wake me up at night. I have...
Do you feel like looking at the humidifier yourself?
You can open the door on the unit, while the furnace is running--
The humidifier is usually installed in the return air duct, so there will be a sucking of air into the open door, when you open it.
There is usually a large wheel, with a wet pad wrapped around the circumference.
This wheel rotates slowly, and picks up water from the sump-- does everything look and sound quiet as it runs? -- The float valve has to open and close, to c ontrol the leve of water in the sump-- (The pool of water the wheel runs the mat thru--
Possibly the valve shutting off, could make a plumbing BANG-- you could duplicate that, by lifting the float mechanism and stopping the water-- does that make the noise?
If you can reach and operate the Humidistat control from near the humidifier, do so a few time-- or Have someone cycle the humidistat a few times, and you listen for that sound--
Is it in the humidifier itself, or the duct work nearby?
It might be that the humidistat wheel scrapes against the side of the sheet metal duct work? -- Sounds travel a long ways in metal duct work!
Let us know if this helps
Mack B
Jan 19, 2011 | Carrier SBP Humidifier
Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
Apr 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
How do I remove the cover to get access to the filter?
Your user's manual should provide you with the information you need. If you no longer have the manual, here is a link for you to download one:
http://www.hunterair.com/ssi/pdf/hunter/33202-Owners-Manual.pdf
Hope this helps you... Good luck!
Sep 23, 2009 | Hunter 33202 Humidifier
Aprilaire 700 never shuts off
Thanks for your question,
Sounds to me like you have a bad solenoid valve in your Humidifier, this will need replaced, the solenoid is supposed to open and close when there is a call for humidity only when the furnace is running, then when the proper amount of humidity is sensed by the humidistat, then will it shut off, with the solenoid not working it will let water flow through like an open faucet, the solenoid is the componet that the 1/4in copper tubing connects to at the humidifier, has two wires running from it, you will need to shut the power off before changing this out, also shut the water off at the valve at the other end of the 1/4in copper line, or you might get soaked,please be careful when installing the new solenoid, making sure the water line connection is secure, or you will have leaks, hope this was helpful, please leave a rating, thanks again for your question,
mr.grzz
Jan 25, 2009 | Aprilaire 700 Humidifier
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Hunter 33202 Humidifier Logo
264 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
Vernon Taylor
mike
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
