when I insert a dvd the display on the monitor shows, disconnected for your own safety. My car has three monitors and they all show the same, please help.
you need to put the dvds handbrake wire to a suitable earth point and then your dvds will play fine i think the wirings colour is a yellow with a blue tracer line on the wire if its an alpine dvd player and the same is on all the monitors themselves that wire will have to be connected to a good earthing point but luckily on the monitors they have a black earth wire running to them so just splice that yellow/blue wre into the black earth wire on each headrest monitor !
what type of head unit are you using its different for each one. e.x. for alpine you cant just hook up one wire and its done, unless its just the monitors (for rear seat entertainment) if its an alpine head unit you need whats called a (TR7) made by a company called PAC. if it is the rear seat monitors from alpine, like the (tme-m710) not sure if its the same for all monitors. you need to look at the wire side of the 10 pin harness where the yellow/blue wire is the second from the top right you need to move that pin to the bottom right position then hook that wire up to ground which should be the wire in the very bottom left pin (black). that will bypass the monitor itself but if the head unit is locked it wont matter start with that first.
It has power but it won't do anything. The light on the front works and it looks like it has power...
(More)
It has power but it won't do anything. The light on the front works and it looks like it has power to it because it has sort of a backlight that is lit when it is dark outside you can see it. The power button does nothing. The remote and other buttons don't seem to do anything either. I can't find the manual. It stays blank screen, but the dvd player is working because the sound is coming through the speakers just fine. The car in question sat for almost a year because the transmission went out and do to financial issues, it is just now getting fixed. It worked fine when we parked the car, but now it seems the screen is not working. Any ideas?
I have recently brought my range rover sport into the UK from Dubai i bought the car new 3 years...
(More)
I have recently brought my range rover sport into the UK from Dubai i bought the car new 3 years ago. The Denso sat nav system does not work apparantly because the software for the middle east OVERWRITES that on the base player.Land Rover want £1200.00 for a new unit and while Denso can convert the unit they are not allowed to deal directly with the customer. Has anyone converted a similar unit or modified the software on the DVD to make it work. my email address is -breid@mbgroup.com -
I have a Pioneer AVH-P3100DVD with the E-brake bypass and the CD-IU50V cord. When I plug my iPhone...
(More)
I have a Pioneer AVH-P3100DVD with the E-brake bypass and the CD-IU50V cord. When I plug my iPhone 3G into it and attempt to play video, it plays the audio through the iPod menu option and the video through the AV1 input, but not both at the same time. How do I fix this?
brought an import with a Panasonic GPS TV 707w in dash, its in Japanesem. i want to convert it to...
(More)
brought an import with a Panasonic GPS TV 707w in dash, its in Japanesem. i want to convert it to English and obtain a manual for it please.
kevin
