Mine too-just happened today...the screen will flash for a half of a second and I can see my background then it goes away--then the light just flashes. I've checked the cables (twice), restarted my computer and still nothing... :( Any suggestions???
Hi this is the way how to
examine what's wrong with your LCD monitors. After you turned it on and the
screen blacked out, you have to check that if you can see the image on the
screen or not by shining a flashlight into the screen, not directly but find
the best angle to the screen and take a look very closely. If you can see the
icons or any image, there will be a minor problem. This is because of the lamps
inside screen. Some of them were broken and it is very easy to replace. You can do it by yourself. Just order the lamps online.
If you
cannot see anything on the screen, there'll be some problems with inverter
board. If you have soldering tool and want to fix it by
yourself, check the caps first. It may cause this problem. Some caps might show
leaking or burn spot on the board because of too high temp. If you don't have
soldering tool, you better go get a technician to do so. Hope this help!! If
anything I can help you with, feel free to let me know. Thank you,
Was this solution helpful? Show your Appreciation by rating it:
This is a generic symptom that could happen to any LCD
monitor.
The following is a generic answer applicable to most.
Two possible causes are bad capacitors or a bad light inside
the LCD panel.
Open the unit and check to see if any of the capacitors in the power supply or
other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often,
1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors
on the inverter board that run the lights. Some times these transistors go bad.
Check the area for any cracked or overheated ceramic or mylar capacitors.
Also, you may have a bad light inside the panel. This is
tough to test without a spare light to use for troubleshooting.
You can take the panel apart and inspect the lamps but it is very tedious. It's
tough enough to get them apart and back together again never mind keeping the
layers clean. You have to try not to get any dust between the layers or you
will see it in the picture.
There are usually two light fixtures each of which holds two lamps. One fixture
is at the top and one at the bottom. Remove them one at a time and inspect the
lamps to see if any are broken or very dark on the ends. If one looks out of
place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace
them, but if you've gone this far, good luck. You should be able to get generic
instructions off of the site that sells the lamps.
Rating Locked! (?) kleonard9245 has rated this solution as Not Rated
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dell flat screen monitor:
