Question about Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi 52 " model WD-52631
52" Mistubishi a buddy has a 52" DLP and almost dead center is a "light" spot. looks almost like a pin light is pointed to the spot. no color, just light is this area. is this a bulb problem ?
  • mitsu_WD Feb 14, 2008
    Thanks, I'll post back after cleaning.........
  • Anonymous Mar 28, 2014
    looks like dust or bugs..could it be between the lens and color wheel
    Champion:
  • 206 Answers
Nope the bulb is fine. This set sucks up dust and contaminates the light engine. Rarley does blowing the set out with compressed air fix this, The light engine can be disassembled and cleaned but this is best left to someone who has done this once before. Because if it gets messed up you get to buy a $1500.00 light engine
Posted on Feb 13, 2008
Mitsubishi tv flashes yellow light
IT might not have been the bulb, it could be the ballast, it could be the power supply. The other things that it might be are the fan, the temp sensor or a bad bulb.
Mar 28, 2014 | Mitsubishi WD-52631 52" Projection HDTV
Outer screen scratch
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Wd 52631 thermistor part number?
Are you looking for one in the power supply? All these parts have a location number on the board where they are located---should be easy to Google the location and model number to get what you want.
Mar 21, 2012 | Mitsubishi WD-52631 52" Projection HDTV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
U can replaced the DLP tv projection Lamp ur self.Try website like YouTube.com.Type in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like Ebay.com,Partstore.com to buy a new DLP tv projection lamp.
Oct 15, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52631 "Check airflow"
mitsubishi is aware of the problem and has issued a bulleteen on this the sensor is the problem. and needs to be replace.,.. i know of no way to bypass the sensor. sense this is a bulleteen issue item it might be covered under warrenty.... check wirh you local service center
Jan 14, 2009 | Mitsubishi WD-52631 52" Projection HDTV
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52631 52" Projection HDTV Logo
309 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
