Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Here are the answers to your questions about my washer
My kenmore washer will do everything except go through the spin cycle. It makes a loud noise like its supposed to be doing something,but nothing happens. My brother looked at it & said there's no belt in it. Iss this an easy & inexspensive fix or should I buy a new washer?
master tech asked some questions regarding this, so her are the answers....
it does fill with water,it does drain & agitiate,I can turn the drum but hand, it has alot of play to it. it doesnt hand spin start with the lid switch pressed in...please answer back.....i need to know if this is going to be an easy fix or get a new washer......oh & the cost of this part please...thanks
  • 1 more comment
  • jiana Feb 14, 2008
    i still need a answer to this problem regarding my washing machine.
  • Lorribelle Mar 03, 2008
    Replaced 3 couplers, will drain, no spin. cannot turn drum by hand in spin cycle.
  • rambrose Mar 22, 2008
    I have the same problem except when i open the lid in spin cycle
    I can see that the washer was not spinning. But if i open and close
    the lid i can get the washer to start spinning.
    President:
  • 1,314 Answers
Is it making a loud rumbling banging sound in spin
Posted on Feb 14, 2008
  • robert samples Mar 28, 2008
    You need a spin basket tub block and nut and a whirlpool tub wrench.You can get that at the appliance store when you buy the tub block .On the control panel locate the two phillips screws at the back or front of the control panel at the bottom where the panel meets the base .Back them out far as you can .Pull the control panel forward and tilt it back(im assuming you've unplugged the washer first) you will see a connector that goes to the lid switch unplug it .Next you will see two gold clips (notice how they go) pop them out with a screw driver .Tilt the washer body back toward you standing at the front and walk backwards with it to remove it .Then unsnap the splash ring from the outer tub and remove it.Pull the rinse cup from the agitator under that you will see a cap remove it .Then you will need a 7/16 inch wrench with a long extension to remove the agitator bolt and pull the agitator.then you will see a spanner nut made of
    aluminum that's where the wrench comes in remove that nut and pull the spin tub under that will be the tub block tap it off the spin tube and slide the new one on .Replace the spin tub and nut using the spanner wrench tighten the nut tight as you can by hand then hit the wrench handle with a hammer to get it tighter.Then reverse the procedure to reassemble.When you replace the body of the washer look down through the lid opening the front of the washer body goes under the base and the sides go on top along the edges. print theese instructions its really not that hard that will fix it
    sorry it took so long to get back to you but i never got the e mail with your reply
  • 770 Answers
Based on your answers your basket drive is out in the unit this is a Major repair $300-$350 or so parts and labor you will have to weight the cost of a new machine verses the repair how old is the machine??
  • Gary Davd
    Gary Davd Feb 16, 2008
    What ever came of your problem Jiana??
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
LOUD RATTLING NOISES ON SPIN CYCLE (SOUNDS LIKE MONEY OR MARBLES IN MACHINE)
you'll need to investigate further. It may even mean bringing in a professional to be sure the vibration damper rods are ok - to prevent future and costlier problems.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer makes very loud noise during the spin cycle.
Sounds like you have bad bearings. If you use powder soap thats the problem. Powder soap doesnt dissolve all the way and gets into the bearings and eats them away. you will most likely have to have a service technician come out to replace them(Its not just bearings they sell you more than you need and you have to take everything apart... big job). After that use liquid soap.
Nov 16, 2008 | Kenmore Washing Machines
My washer wont go through the spin cycle
I poked at the sensor (sensor that is is the safety lid switch) which is on the right hand side of the top of the machine. The water pumped out and it went into spin cycle. When I released the switch or lever to activate the sensor, the cycle stopped. I then proceeded to unscrew the sensor switch. I carefully I pushed the sensor pad up (It was stuck). Screwed the switch back in place and ...Wha la! She is running like a top. This sight is very helpful. I love not having to pay anyone to fix my problems! Kudos!!!!!!!!!!!
Thank you!
Feb 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
167 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
