Question about Mitsubishi VL-2000 TV
Lamp won't turn on
I just purchased an old mitsubmish vl-2000 projector that seems in great shape. I'm unsure if the lamp is good, but when I turn the unit on there is no light. the standby and lamp light are red and the fan is going. Can you help explain?
    Champion:
  • 206 Answers
Afraid there no way to field test this style of lamp It will show as a open on a test meater so the only way to see if it's the lamp without going and testing ballest voltages and scoping turn on pulses is to replace this spendy lamp Part # 499D046030 for about $350.00
Posted on Feb 13, 2008
How can you display the lamp hours on a Mitsubishi XL5U
If the lamp is in great shape it doesn't matter its just a timer for our benefit.
Feb 07, 2013 | Mitsubishi XL5U ColorView Multimedia...
Tip
Before buying a projector bulb
1. Always be aware of bulb usage hours: bulbs normally last ~ 2000 hours
2. If the bulb pops and goes out:
  • Follow the manufactures safety instructions for this condition.
  • Normally, the bulb will need replacing.
3. If the lamp just turns off:
a. If lamp hours were getting high and the picture was getting progressively dimmer, normally the bulb will need replacing.
b. If bulb hours were low or a few hundred hours from 2000:
  • Clean all filters and air ports.
  • Try the projector again checking overall projector ventilation.
  • There is a heat sensor in most projectors that will shut off the machine if it overheats, so air flow must be unobstructed.
c. If ventilation does not solve the problem:
  • Take out the lamp, following the manufactures instructions.
  • Inspect the lamp bulb visually through the lamp glass window.
  • Look for cracks or damage in the bulb and whether one or both of the lamp wire elements is detached from the top of the bulb.
  • In either case, the bulb is bad and should be replaced by purchase or possibly by warranty if the lamp hours are low.
  • Normally, bulb replacement is the solution, but other issues could also exist.
d. If the lamp looks undamaged and/or you are unsure of the status, the problem could be a lamp ballast, power supply, or main control board issue, and should be evalulated by a technician. Unfortunately, a bad bulb can also result from one of the above issues.
on Feb 12, 2011 | Office Equipment & Supplies
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
When I put in the new replacement, the tv won't turn on. All I get is a few short bursts of clicking and then it turns off. I think it is because the ballast is not seating properly, but am unsure...
Definitely lamp is not installed properly if TV was working fine before replacment.
Also check for wright part number on new lamp,or new one is defective.
Aug 15, 2011 | Panasonic TYLA1001 TYLA1001 Projector Lamp
I am told the light is very dim. Is this a sign the lamp is going bad?
From the first moment it is used, the lamp in a projector is losing lumens (a measure of light). Most projectors' lamps are good for 1500 to 2000 hours of use. Even at the halfway point, a significant dimming can be noticed.
If you do not have many hours on the lamp, you may have a defective lamp and should seek some sort of compensation from Mitsubishi or whatever retailer you purchased the projector.
Mar 09, 2011 | Mitsubishi VLT-XL8LP Projector Lamp for...
Newer lamp not workering
I don't think that resetting the lamp is the problem if you have had it in there for a few months already. This lamp is rated for 2000 hours. That is abaout 1 year if you use it about 5 or 6 hours a day. If you don't use it that much you should get close to 2 years. There are a variety of factors that will reduce the life of your lamp. Do you let the fan continue to run after the projector is turned off? If not, you will see about half of the regular life. Are the filters clean? You can use a vacuum or rinse out foam filters to clean out the dirt and dust. The lamp needs good air circulation to cool evenly. Are the vents blocked or close to another componant? I'm pretty sure that you just need another lamp. If the lamp was purchased more then 4 months ago, you are probably out of warranty. You can save yourself some money if you buy the bare bulb and replace it in the old cartridge. It looks like the complete lamp module from Sharp runs around 295.00 but the usually have a bare bulb available. We supply a variety of brands fior each projector. You can contact me at 866-470-9877 or go to allprojectorlamps.com. Good luck!
Jun 26, 2010 | Sharp XR-11XC DLP Projector
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 12, 2010 | Sanyo Lamp for PLV-Z2000
The amber led labeled lamp lit up on my optoma ds303 and the picture disappeared. I replaced the original lamp with an after market lamp I purchased online. It worked for 2hours or so then the amber lamp...
the reason that it turns on without hitting the power button is that it thinks it's still in cooldown mode. while it's on, check the lamp hours through the menu. if it's close to 2000 hours (or the inside of the lamp is blackened or bulging), replace it. after market lamps never seem to last that long. if the fans stay on when the lamp goes off, it could also be the colorwheel. listen for chirping. if it chirps, it's the colorwheel.
Nov 17, 2009 | Optoma DS303 DLP Projector
PJ-TX100 Projector won´t start up out of Stand-By
Hi Mario
If there is no response on the Projector it normally means that the Mainboard is faulty.
Check if your machine is still under warranty because this quite expensive to replace.
As far as the schematics are concerned - I'm unfortunately not able to help you out with that.
Apr 02, 2008 | Hitachi PJTX100 Multimedia Projector
VP6310 Colour problem
You need to replace the color wheel sensor. I can fix it.
Dec 10, 2007 | HP VP6310 Multimedia Projector
Televison & Video Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
