Question about Breadman TR2200C Ultimate Bread Maker
Power I used the machine this morning and the machine worked fine.  This afternoon, when I plugged in the machine, no beep, nothing on the readout.  Thought it was the outlet, tried another, no luck.
  • jenkins007 Mar 09, 2008
    LCD display will not turn on. Internal light turns on when lifting the door.
  • Anonymous Mar 26, 2014
    Just used my machine the last two day's and when I went to plug in machine it wouldn't beep to say that it had power and was ready. tried differ outlets and that was not the problem.
  • 25 Answers
I had the same problem with a tr2500bc.
I took it apart and found a bad soldier joint reapaired it and it is ok now.
Posted on Jul 24, 2008
  • gunpowder201
    gunpowder201 Sep 14, 2012
    Mine was dead on delivery. (gift). I tried all the reset hints to no avail. I ended up taking the board off and running a dental pick along the solder joints of the two micro chips and it came to life. Must have been some solder touching
How do I reset control panel on km Elite mod #11022032100 top load washing machine?
did you check to see if the power is working first and didn't blow the breaker. then try plugging it back in. and is the machine loaded, if you can empty the machine see if it does anything
Feb 12, 2015 | Washing Machines
On model PLEF398DCH Frigidaire Professional Series electric range, my digital readout for the right side burners works fine. My left side digital readout is inoperative, but the burners work fine. Is there...
Good Afternoon Lee,
I understand that the left hand side digital readout is not working on your Frigidaire range, model# PLEF398DCH. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Once you restore power, you will need to set the clock and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Kitchen Ranges
Asus u50f labtop not turning on anymore even with powercard plugged in and charging light on. This morning the labtop was working fine. It was put in hibernate mode. In the afternoon pushing the power...
Before you panic see if there is some hidden reset code from the manufacturer. If not, then you get concerned.
Check to see if you are using the right protocol to get it out of the hibernate mode.
Sep 08, 2017 | ASUS U50F Notebook
Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
I had the same problem this morning. I seasoned it two days agao with an outside temp. of 50. This morning it was 8 degrees and when I pluged it in there was no readout. I removed the digital unit from the top and heated it with a hair drier and it worked when I reinstalled it. I think it had some moisture in it although the unit has been covered the whole time. I am going to call Masterbuilt tomarrow and see what their answer is to this problem.
Jan 17, 2009 | Masterbuilt 20070106 Electric Smoker
Won't turn on I press the power button
Press the reset button on the back of the unit with the stylus tip.
Apr 23, 2008 | Palm Tungsten E2 Handheld
Sharp AR-207
I am sure that I don't have to say check the power switch, so you probably have a bad power supply, either not enough voltage, or maybe there was a strong enough surge to knock it out.  Needless to say, if it's under warranty, you should get it serviced.  If not, it'll probably be too costly, and would warrant a new machine.
Oct 26, 2007 | Sharp AR-207 Copier
Kenmore Model #731893 Room Air Conditioner
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Aug 07, 2007 | Kenmore 73189 Air Conditioner
Breadman TR2200C Ultimate Bread Maker Logo
144 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
