Question about Dell Inspiron 6400 Notebook
Why turbo c does not work in windows 7 64 bit
  • 44 Answers
You're a programmer you should know this. Turbo C is a 16 bit application. 64 bit operating systems cannot run 16 bit applications. You need to get the 32 bit version of Turbo C or upgrade to a newer compiler.
http://www.fileguru.com/apps/turbo_c_for_windows_7_32_bit
Posted on Jan 22, 2010
    New Friend:
    Problem Solver:
  • 9 Answers
Strongly recommend you go to https://www.facebook.com/Windows-7-Professional-406869716183210 get windows key
Posted on Jan 11, 2016
    New Friend:
    Problem Solver:
  • 13 Answers
This website does help me a lot. If you are in need of windows product keys or have other problems, you can have a look at it. Hope it can also help you. www.fastbackorders.com
wish you good luck
Posted on Sep 15, 2015
SOURCE:
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
I am using windows 7 ultimate 64 bit OS. i am having turbo c++ 32 bit software.how can i install it in my laptop...
The Turbo C++ you are trying to install is just incompatible for your OS. Because your OS is of 64-bit and you are trying to install 32-bit one. Try to find a 64-bit Turbo C++ program.
You can try downloading this one for 64 bit compatibility:
Turbo C++ for 64bit
Dec 19, 2010 | Computers & Internet
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
http://support.microsoft.com/kb/314106
http://support.microsoft.com/?id=165214
http://support.microsoft.com/?id=324767
Generaly speaking this error shows up when a program tries to use a
command.com file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
Error: Will not print
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Feb 20, 2008 | Dymo LabelWriter 320 Thermal Printer
Dell Inspiron 6400 Notebook Logo
695 people viewed this question
Clive
Clive
Alun Cox
