Question about Canon PIXMA MP160 All-In-One InkJet Printer
Sanning problems for multi function printer PIXMA MP 160
I can print off things from the printer but cannot scan from it – will not work. It has not worked since the printer inks ran out. Can you normally operate the scanner even though the inks run out? Since then I have had the ink cartridges refilled instead of replacing with new ones, and the scanner still doesn’t work.
Once I turn on the printer, the LED flashes along with the black and colour ink lamps and the alarm lamp remains still – even though I have replaced the ink.
I then tried clicking on the MP Navigator icon and when I press preview or scan, the scan gear box comes up with the message “printer maintenance in progress, scan after it is complete – code 2,114,0”. Once hitting the ok button, nothing happens. I tried the same progress the other day and then the message displayed “scanning failed”.
Are these problems happening because the printer has not got new cannon ink cartridges?
BTW can you please give me the phone number for the NZ Cannon technical support line?
Thank you,
Maria
  • 9 more comments
  • Anonymous Feb 23, 2008
    I have the same problem only with a mp210, but it's the same thing..
    I wonder, if i'll change the both cartridges will it work?
  • Anonymous Feb 26, 2008
  • Anonymous Mar 09, 2008
    how to change out the ink cartilge out
  • Anonymous Apr 13, 2008
    Since my black ink cartridge has run out, my scanner doesn't work either. What's the connection between the scanner and the printer? And how do I fix this?
  • geordiepom Apr 13, 2008
    I copied a photo to my computer but was unable to do another one . I have done this many times without problem Wizard says "cant complete process was canceled" I have turned both computer and scanner off and rebooted but this didn,t work
  • Anonymous May 07, 2008
    Given solution doe not answer the problem.
    "printer maintenance in progress 2,114,0"
    what maintenance? How do i make it stop doing that?
  • mart44 Jun 12, 2008
    same
  • Morrisette Jun 18, 2008
  • yakko_next Jul 14, 2008
    i have same problem with my canon mp210..... error 2,114,0
  • mm018x2710 Nov 03, 2008
    Have same problem with a canon pixma MP520 why is happening to all these model's
  • sojnol May 11, 2010
Just hold the stop and reset button until the warning goes away. Works like a charm
Posted on Feb 11, 2010
  • santuchat Jul 12, 2010
    This worked superbly with my cannon pixma mp140
Okay all, I have an MP210 and I had the same problem using it on a Mac. My color ink was running low, and after a final printout it informed me that I was out of ink altogether. Now, the next day I want to scan something, so I bring on MP Nav EX, but it gives me the "maintenance in progress" error. I contacted Canon support and this is what they had to say:
"Unfortunately, the PIXMA MP210 must have all of the inks installed and contain ink for the unit will be able to print. If you are experiencing a "Low Ink" warning, you will still be able to
scan, but not print. If you are getting a "Ink Out" error, you will NOT BE ABLE TO USE the unit for copying, scanning, or printing until the ink is replaced. These precautions are in place to prevent damage to the printer from occurring if printing with no ink is attempted. As the process of scanning is the same as copying for the MP210's hardware, this is a part of the design for this model."
So while this model may seem stupid and inefficient, it is there for a reason. And now you know! :)
Posted on Nov 24, 2009
  • bobalvarado Nov 06, 2010
    The purpose of this design is probably more to insure the sale of ink cartridges. Their business model is to sell the units at lower costs and make up "lost" revenue through recurring sale of ink. Is not "stupid", but clever and effective - though underhanded and counter to the consumer's interest.
Got the same bloody problem. Should I smash the printer?
Posted on Sep 13, 2009
I have the same problem, any body got a solution
Posted on Apr 30, 2008
    Guru:
  • 377 Answers
Hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Posted on Mar 23, 2008
THIS SOLUTION FOR PEOPLE WHO CANNOT RESET THEIR OWN PRINTER LIKE ME
hi, now i got a solution how to SCAN if your printer have E-5 error or something. First u must remove the both cartridge from your printer and make sure u connect your printer to your computer, after that, do this
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
And then you will see no error in your printer (the LED shows number 1,and the alarm is in green)
NOW U CAN SCAN USING MP NAVIGATOR!
Posted on Apr 28, 2010
  • jananimanian Oct 07, 2010
    can you be more specific ... whether we have release power as well as stop/reset button after it got switched on??and if again pressed power button with stop.reset button my printer is simply switched off....
    Thanks in advance
  • 25 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
529
Posted on Feb 27, 2009
Yo Baje el el programa (MP Navigator) de este link http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15294#DownloadDetailAct y posteriormente presione durante 5 segundos el boton Stop/Reset de mi impresora y listo ya pude scanear documentos. Cualquier duda me puden escribir a juliojose.gonzalez@gmail.com
Posted on Jul 08, 2008
I have a Canon Pixma MX882? How do I scan to my computer?
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Sep 26, 2011 | Office Equipment & Supplies
I have a cannon MP 160 printer/scanner. It does not work on a Mac
Uninstall all your drivers (and delete the preferences) and download the Mac drivers from this link. The drivers that came with your printer were developed before Snow Leopard came out.
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Jun 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Pixma mp 160
hi,
tokl-4
Oct 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
May 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
PIXMA MP470
Canon 470 printer scanner stopped scanning, Bill
Feb 28, 2008 | Canon PIXMA MP470 All-in-One Printer
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
10,133 people viewed this question
old marine
old marine
