Question about Craftsman 17762 Wet/Dry Vacuum
Craftsman 20 Gal Wet/Dry Vacuum model number 17762
I am in the middle of pulling water out of my basement (due to heavy rains) and managed to fill the vac four time. Upon the fifth filling I find that it is not pulling water into the vac. It seems to be blowing. I must have hit something by mistake. I cannot find the manual (embarrassing) and don't know how to make it work poperly. Please help. Thank you.
Eloise Peterson... westportsps@gmail.com
  • Eloly Feb 13, 2008
    Thank you. I had previously removed the filter before using it the first time. I don't see a "check ball" in the filter housing. But upon trying it again it worked...I think. I had filled the tank four times today before encountering this problem. I do appreciate your kind attention. :)
  • Anonymous Mar 31, 2009
    to vac water where does the hose get connected to, do I remove filter first.  what else must be done
    President:
  • 1,314 Answers
You did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Posted on Feb 13, 2008
How do i use the vacuum for water suction? (the "floating ball" is missing)
Hi dskordas...
Remove your air filter...you only have to worry about the "floating ball" if you get too much water in your vacuum...it will then **** water into the blower and motor of the vacuum ...not good.
Dump your vacuum and you will have no problem with the water getting too high and causing problems.
Please take time to rate me
Sep 18, 2011 | Craftsman 17762 Wet/Dry Vacuum
Craftsman wet dry vac no longer sucking enough to use, cleaned the filter, sounds strong but barely works??
Buy a new filter. Make sure hose is cleaned out. Sometimes if the filter is wet and not allowed to dry it will do that. Also make sure hose is on the right outlet
Dec 30, 2010 | Craftsman 17762 Wet/Dry Vacuum
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Wet/Dry Vac Leaking
are you using a water , foam material filter?
Aug 01, 2009 | Craftsman 17762 Wet/Dry Vacuum
RE:removeal of filter
some filters just pull straight off, while others have a large plastic knob that unscrews to remove the filter. if it is a foam filter, it is just a stretch fit and pulls off, though it usually tears.
J
Jun 11, 2008 | Craftsman 17762 Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Craftsman 17762 Wet/Dry Vacuum Logo
394 people viewed this question
Top Craftsman Vacuums Experts
downhille
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
