Question about Garmin Nuvi 660 GPS Receiver
Installation / wiring
Hello , after purchase and mounting the nuvi 660 I would like to hard wire the unit into my truck so that it is not powered by the cigarette lighter plug in deal
should I cut the end off this power cord and strip it back a little and find a fuse proteceted power source? or is there another part that I can get so that when I take this unit to another vehicle I have a power cord??
  • jaymon Aug 06, 2008
    I have a Garmin 760 and I want to have a hard wire connection to the fuse box. I purchased the additional cigarette lighter that is used for this kind of power installation. My question is how do I attach the two wires to the fuse box. No wires are in view, only the fuses
  • 174 Answers
The input voltage 12vdc for the cigarette is correct, but many of the adapters have a stepdown voltage to 5vdc built into the adapter. So before cutting the adapter verify that it is still 12vdc coming out at the other end, otherwise you could toast your Nuvi.
My nuvi 350 uses a mini USB plug and I know for sure that the voltage is stepdown from 12vdc to 5vdc.
Posted on Feb 14, 2008
  • audiqv8 Feb 14, 2008
    You might want to seach ebay for "Nuvi Hardwire" or Google "Nuvi Hardwire" for more info.
  • Garmin Master
  • 2,130 Answers
Yes, you can do what you said above. The only issue I see is that you should still add an inline fuse between the GPS and the power source you will be connecting it to.** SEE NOTE BELOW **
The cigarette lighter plug has a fuse in it. Most of the fuses you have in the car start at 5 Amps and go up in value, like 10A, 20A, etc.
The problem is these values are way too high should the GPS have a catastrophic failure or the GPS power leads get pinched or shorted to ground. You'll burn up the GPS and its wiring before the auto fuse blows.
You need a low rated fuse (probably 1/4A) inline with the GPS. This will give you adequate protection. You can buy inline fuse cords at Radio Shack.
** NOTE **
Check to make sure that the DC output of the cigarette adapter is indeed +12VDC and not some lower voltage indicating that there is an internal regulator circuit. I took a look at the 660 owners manual and it says the GPS input voltage is +12VDC, so you should be ok. I also hear there is some electronics inside of the cigarette lighter plug. It may have to do with charging the internal GPS battery. You could always take apart the cigarette plug and remove the internal board and use it in your hard wiring to your vehicle.
Once you get it all working, you could duplicate what you built for another vehicle. You can buy the cigarette adapters online.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
  • SHARCNET-USA
    SHARCNET-USA Feb 13, 2008
    I originally said 1/4A fuse. You might have to go to a 1/2A or 1A fuse.
Garmin 660 touchscreen inoperative
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 18, 2011 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 turns on but displays "loading maps"
The problem is that the nuvi 660 gps receiver is jammed and needs to be reformatted.
What you have to do is to disconnect the gps, and connect it to a computer, then format it.
After formatting it, you download the self extracting archive files for your nuvi on to your hard drive, then connect your nuvi to a free USB port on your PC interface cable and allow your nuvi to initialize and enter USB mode, Unzip the files by running the downloaded executable files, then follow the instruction provided by the launched update application on your PC.
Then install it back in your car and turn it on, it will work once again.
Take care and good luck
i hope this helps?
Dec 05, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 660 "Display unit " won't seperate from mount
If you have the suction cup holder in the middle of the bottom of holder there is a tab there... hold gps while thump underneath and press thump upward to release and pull out unit
Mar 13, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
Speaker of garmin nuvi 660 doesn't work anymore
Bruce,
I measured a speaker on a Nuvi that I had opened up on my repair bench. It measured 7.8 ohm. I'm pretty confident that your speaker is bad.
- Jim
Sep 05, 2008 | Garmin Nuvi 660 GPS Receiver
I am looking for a hard wire kit for a nuvi 350 by garmin including the mount
Hello ledgeviewfd,
The installation kit for the Nuvi 350/360 (including power cord and mount) is available directly from Garmin on the website.
https://buy.garmin.com/shop/shop.do?pID=8125
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 25, 2008 | GPS
Replacement battery for Garmin Nuvi 660
utube.png You-Tube video "S2KEu_if7wA" placeholder
I discovered a recently posted video showing how to change the Nuvi 660's battery. I purchased a battery from newpower99.com and they took care of me well. My little "surgery" went smoothly with their kit.
May 14, 2008 | Garmin Nuvi 660 GPS Receiver
Attaching the portable friction mount
It should be the same as mounting it to the suction mount that came with the 660. Check the sizes, they should be the same. There are instructions on the supplied cd, but also in the built-in memory, visible when you connect it to your computer, and if that is missing, on Garmin's website. It does take some force, but it shouldn't feel like it's going to break something.
Apr 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Hard wiring the Nuvi 660
Make sure you use the proper kit for hardwiring. The Garmin DC adapter setp down the voltage from 12vdc to 5vdc. If you don't get the right kit you could fried your unit.
Nov 02, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
158 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
