Question about Sega Game Gear Console
My sega game gear sound has no sound how can i fix it!
My sega game gear has no sound,was working perfectly until i lent it to a friend!.any ideas on how i can fix it?.thanks
  • 47 Answers
Might need a new headphone jack due to rough handling or a new volume pot. try plugging in headphones and wriggling them gently to see if you get sound, if that does not work try fiddling the volume knob, whichever gives a burst of sound will show you which needs to be replaced.
Posted on Feb 19, 2008
Why is there no sound on sega game gear
This is usually due to old capacitors that need to be replaced on the sound board. Follow this tutorial to replace them.
Cheers!
-Gerry
Jun 28, 2014 | Sega Game Gear Console
How to fix a stuck button on game gear
This is an easy fix. Open the Game Gear by removing the back panel. Take off the front panel, and the buttons and pads will come up. Remove the pads and buttons and clean the pads, buttons with alcohol, to remove the dirt and gunk around the buttons and pads . When finished replace the cover. Test the system. If the pads do not respond to the game, the pads may be worn down and may need replacing. There is a website called Ifixit that has the parts for the Game Gear. Go to ifixit.com to get the parts. Or go to Sega.com for help. Also call 1-800-872-7342. This is the number for SEGA . Hope this information helps.
Jan 10, 2014 | Sega Game Gear Console
I just bouggt a sega saturn and it works perfectly other then whenever i go to open the drive door it doesnt open all the way it has a little catxh in it and if i use my hand i can open it all the way, and...
To fix this you have to remove 4-6 screws to take off the top case. The mechanism that opens the CD draw is a mixture of a spring and a gear mech and is attached to the top lid. You will have to pull to pieces and clean it. Hopefully it is just some dirt or grease in the gear mechanism that is stopping it from gliding open. If it is a broken tooth on the gear you have to find another Sega Saturn to fix this. It may also be a broken spring, if it is a spring another may be harvested from any unit that is a top loading CD and rigged in.
Nov 03, 2013 | Video Game Consoles & Games
I have a sega Game gear which my nephew just found in our attic. No batteries in it, put new batteries in it worked perfectly for about an hour then the screen just went white and lines appear on it now...
Do a search on the net for Game Gear display repair. There is even videos on YouTube that show how to make the repair.
I would suspect it it the capacitors that have failed. The display, and the sound issues are easily repaird by installing new caps. Seek someone who is good at soldering small parts on a circuit board. The cost of the parts should be under $10.
These are common issues with the GG, so if you decide not to have it repaired, there are still those of us out there that would buy your unit to repair.
Good luck.
Mar 31, 2010 | Sega Game Gear Console
How to fix the sound on a sega game gear 2110. everything else is working fine but the the sound is shot.
Hi Jeremy,
This is an easy repair, if you are used to working with a 15 watt solderin iron, and have a little experience with solderin small parts.
The sound board needs new capacitors, it is a common failure. I believe there are 6 of them, and the cost should be under $10.
This repair works well, but the capacitors that are in the display secton can go out too, at a later time. If you get to the oint where you must tilt the display at an angle to view, the caps are probably failing. Again, it is a matter of just replacing the caps.
Here are two videos that detail the repairs.
Feb 20, 2010 | Sega Game Gear Console
Sega Game Gears will not stay turned on
It sounds like a battery issue replace the batteries.Plug it in to the wall if you have a plug in.
Aug 14, 2009 | Sega Game Gear Console
Sega game gear turns on but the screen is black with a few grey lines
i think that means the cable from the sega to the t.v is faulty or loose try riggling it around if its not that try a different channel
Apr 26, 2009 | Video Game Consoles & Games
Sound And screen problems
Change the capaitors common fault.
Apr 20, 2008 | Sega Game Gear Console
Sega Game Gear
try adjusting the brightness knob on the system. i once had that same problem with mine. The ccfl tube (the main battery drain problem in most portables) might be burnt out or something. You can replace it with LED's i think.
Nov 24, 2007 | Sega Game Gear Console
Sega Game Gear Console Logo
302 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
