Question about Ovens
Cooker glass insert in cooker done has come away, can it be resealed by diy? tricity bendix cooker si 453 model. 7 years old. thanks.
  • 4 Answers
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Posted on Feb 14, 2008
How do I get the front door panel of a tricity bendix topoven as I want to wash it.Thank you
The glass panel is not intended to be removed, washed, and reinstalled.
Jun 06, 2016 | Ovens
I have a Britannie Range Cooker SI-12T76X2-CL-GC about 5 years old, the hob has been converted to LPG, I have got the new jets to convert it back to Mains gas - how do I do it? Thanks
Get a gas fitter This is not something to be done by an unqualified person The potential for damage if done wrong isnt worth the couple of hundred bucks a gas fitter would charge
May 28, 2011 | Ovens
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Tricity bendix president sb430 cooker. The 2 small hobs will only heat up to full ie they are off or on full and nothing inbetween.....help please
You need to replace the regulators that control the heat settings.
Please rate my solution.
Thanks.
Nov 06, 2009 | Ovens
Trying to Find User Manual.
I can't find a manual for free.
Here's one for $9.95:
http://www.user-manuals.com/advanced_search_result.php?keywords=sg335xn
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 23, 2009 | Ovens
Tricity Bendix SIE504W oven overheating
I have had a similar problem in that the top oven was overheating getting hotter and hotter and have just got a replacement thermostat from Partmaster.co.uk. This is to fit a Tricity Bendix from Currys model number DSIE520 GR. The new one seems just like yours in that it has three lettered connectors A,B and C. With the part came a sheet stating that for a free standing appliance with NO timer (this what my cooker is) the connections to be made are : 2 on old part to A on new; F on old to B on new; G/H on old to C on new and the link from G/H and 6 on old to be removed or "severed". I haven't yet done this as its in my cottage which I'm going to this weekend. Good luck! James
Aug 11, 2009 | Electrolux Ovens
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Tricity president double oven
if this a uk model and less than 15 years old you can ring tricity,they should be able to supply you with a manual
www.tricity-bendix.co.uk
Mar 06, 2008 | Ovens
Ovens Logo
296 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
