Question about Kenmore 62062 Electric Dryer
Timer on dryer counting down too fast
Kenmore Dryer model # 110.62062100, unit would go from 52 mins to 45 mins to 20 and then 5 and shut off. Unit would not run the complete cycle? Control board has been replaced already and didnt solve issue. Any ideas??
  • voltmeter Feb 15, 2008
    Thanks Jimster! One of my techs changed it out. He is going back to change it out again to find out if it was a bad part or not.
  • njcarter Jun 04, 2008
    I think I have the same problem. I set it for 50 minutes, walk away, and about 15 minutes later it's in the "off" position, clothes obviously still very wet. There is definitely spinning and heat going on in that 15 minutes. Dryer is about 6-7 years old. Worth repairing? Anything I can easily check myself?
  • 240 Answers
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
  • James Greene
    James Greene Feb 15, 2008
    Ok, great, let me know how it comes out.
Whirlpool Duet dryer time skips mins.
clean the stainless steel sensor pads located just inside the dryer door with isopropyl alcohol,these sensors register moisture in the garments and adjust drying times accordingly,when you use dryer fabric softener sheets it coats these sensors and throws the system off,make sure to shut off power to unit as this alcohol is very flammable,then leave door open to air out before re-powering up unit
Apr 24, 2012 | Whirlpool GEW9250 Electric Dryer
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
Timer counts down but doesnt shut off
same problem with Kenmore dryer Model No. 110.96250100. The timer would not advance under any setting. I replaced the timer and it only advances under timed dry but does not shut off when it times out. Under all other settings, the timer knob does not move, but the temperature stays warm. I checked the continuity on thermostats and resistor and, to the best of my knowledge, all passed. all in all, it appears to be a mechanical problem with your timer.
Please remember to award your selected response
Jan 11, 2011 | GE DNCD450EA Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
appliancepartspros.com
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
My Kenmore drier won't stop now! Perhaps timer isn't working?
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Mar 06, 2009 | Kenmore 84052 Dryer
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Kenmore 90 series gas dryer
The trouble is actually with the start bearings in the drive motor,I bet you have a small hummmm or GRRRRR right at the start, as if the unit wants to hesitate.
Anytime you have a dryer that starts then shutsoff and must "cool" down, it is the motor.
Feb 18, 2009 | Kenmore Dryers
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Timer doesn't shut down dryer machine
the timer is easy to change, check how much it is first, mine was around $100.
Apr 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62062 Electric Dryer Logo
1,056 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
