Question about SanDisk Sansa Clip MP3 Player
1g sansa mp3 clip
My mp3 player is fully charged but when i disconnect it from the computer it says battery low and shuts off. i have never had a problem before. any suggestions
  • 8 more comments
  • Anonymous Feb 14, 2008
    It's not get charging properly...when i disconnect form the system,Its shows like battery low and shuts down...
    Its 2GB Sansa Mp3 player...
  • bina08 Feb 21, 2008
    when i disconnect from the computer it shuts off with low battery sign on screen though it shows fully charged when connected.
  • EXPE Feb 29, 2008
    My brand new sansa clip does the same thing. Always low battery, never charges to full battery and after overnight charging still shows low battery and shuts off.
  • Anonymous Mar 01, 2008
    I charge it, and then the battery is dead when I turn it on
  • Anonymous Mar 05, 2008
    my battery only charges halfway and lasts 1 hour just bought it
    my mp3 player is fully charged but when i disconnect it from the computer it says battery low and shuts off. i have never had a problem before. any suggestions
  • Mookie252 Mar 08, 2008
    Step 1-Plug it up it's Charging
    Step 2-Kept it up there for 3 days
    Step 3-Took it off tried to cut it on 10 times
    Step 4-Still didn't come on
  • LilysPapa Mar 17, 2008
    New 2G Clip won't fully charge, even overnight.  Maximum battery life about 2 hours on FM radio, far less than the 15 hrs advertised.
  • Anonymous May 13, 2008
  • 8,596 Answers
Download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Posted on Feb 19, 2008
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip was working yesterday and when i woke up i turned it on and the lights started blinking and it shut down what do i do?
Try Fully charging the most electrical equiptment have a reserve built in its battery so you are able to switch on by going off again Batteries need fully charging. If you have done this then your battery does not hold its charge Sorry but they need replacing.
May 22, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip won't charge sometimes. it will display the "connected" screen and a fully charged battery but when i unplug it, it will tell me that battery is low!
Hello
first you have dirty battery terminal and need to clean, second you have weak battery and need to replace a new one...
Angel
Thanks...
Jul 31, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
307 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
