Washing machine approx.2 y.o. ,will not go into spin cycle.Trips circuit breaker also.
  • 6 more comments
  • TN cowgirl Feb 13, 2008
    washer is a Kenmore Elite-model-110-24954300.Thanks
    will not drain -Help!
  • TN cowgirl Feb 14, 2008
    Yes, it washes fine. i think it was in the rinse cycle,when the
    circuit breaker tripped. It did not have a large load in the basket.
    It was on small load with 2 ball caps. Thanks,
    tech 17 -switched cord to top recepticle.Yes, it washes fine,rinses--but will not
    spin--it is on small load.Right now -there is 3''-4'' water in tub. Thanks,.
    It agitates fine --everything is o.k.--except the spin cycle.
    I am not brave enough to set it on full load.Thanks
    tech17, Console panel back is off,I looked around and
    checked to see if all is plugged in. I do not know what a jumper
    wire is--but you are right about the lid switch. Spin is not functioning
    in any of the cycles--Thanks
    Thank you tech17--you know your stuff!!!!!!!!!!!!!!!!!!!!!!!1
  • robert samples May 11, 2010
    does it wash ok you from tenn
    President:
  • 1,314 Answers
Have you tried to wash again since the drain promblem if not turn it to wash now and pull the knob out see if it agitates for me
Posted on Feb 14, 2008
  • robert samples Feb 14, 2008
    ok if all the water drained this time and it didnt trip the breaker then we have a possiable bad lid switch if you look on the back of the control panel toward the bottom of the end caps there are two screws back them out and pull the panel slightly foward then tilt it back on the left hand side you will see a small plastic switch unplug it and put a jumper wire across the terminals to bypass the switch then put it on spin see if it spins
    you welcome
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Samsung SW81ASP trips circuit breaker on SPIN cycle :(
Just had a samsung repair tech come out today to fix this issue. He said the issue is the breaker. They can not run on a D breaker. Need a GE or Seeman's breaker. That is what he said. I guess we'll see if that fixes the problem.
Mar 13, 2012 | Samsung SW62ASP Top Load Washer
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Washer trips circuit breaker during spin cycle
try unplugging the motor then put onto spin it will pump out ok and run othewise spin if all else is fine ,next reconnect the motor if it trips again then motor ' fault; repair /replace.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer fills but trips breaker when trying to start wash cycle. Does the same with rinse and spin cycles and when plugged into another circuit
Hi there
OK thank for writing to fix ya. Sounds like your breaker can't support your washer so you need to replace you breaker where it can handle you washer. just go up another 30amps on your breaker and try that. let me know how that goes.
Best regards Richard
Dec 08, 2009 | Washing Machines
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Flashing lights and trips the electric
Are you around when the breaker trips? It almost seems as though an electrical connection is getting wet. Especially if it won't let you reset the breaker. Another reason for not letting you reset the breaker could be an overload that tripped but that to me would be within the machine, it shouldn't trip at the panel. You get pull the machine apart and check for these things. Look for and wetness or wire connections being crossed, anything like that. Something at the spin cycle is shorting out and tripping out your breaker. Also is your dryer circuit properly sized (30AMP Breaker with 10/3 wire)?
May 26, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
