Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Print head does not move after power on. Message says, ' check printer press resume key ' with alarm light blinking. Problem arises after nozzle check maintenance performed. Thanks. akyaw
  • mntman1 Sep 29, 2008
    I changed ink tanks,I put wrong ink tanks in now cartridge wont return to remove wrong ink tanks.
  • Anonymous Oct 15, 2008
    i hate this thing
I have the same problem.good luck buddy
Posted on Feb 17, 2008
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
I was printing the other day and each page got lighter and lighter and now it doesn't print anything in black. There's ink in it and I turned off the printer. What else do I need to do to get it to print...
How long has it been since you printer prior to the other day ? If you do not use your printer for some time, the ink will dry out even if it's a new cartridge.
May 01, 2009 | Canon I960 InkJet Photo Printer
My canon i950 waste ink absorber is almost full
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
Mar 17, 2009 | Canon i950 InkJet Photo Printer
Canon MultiPass F60
You need to do the print head cleaning. The steps are listed below.
Print Head Cleaning / Head Refreshing
If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
1. Press the <Menu> button on the printers operation panel.
2. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
3. Press the <Set> button.
4. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
5. Press <Set>.
6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
Sep 15, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon mp-730 print head does not move
it seems you open or unscrew the printer.
this may happen if the mother board has no nigative pole.
you have to reset the mother borad.
cannot do that from the available options
the reseting procedure is to take the motherboard out and you have to shortcut the battary for 10 seconds.
re install it , and try it
Feb 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
3. release RESUME
Number of presses - light color - function :
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
232 people viewed this question
old marine
old marine
