Question about Samsung Digimax A7 Digital Camera
Samsung digimax D103 10 million pixel camera
When I turn the camera on the lens shutter will not open and the lens does not move out I have tried fully charged 2500 rechargable batteries with no avail this camera is a little over a year old but has not been used that much at all about 6 or 7 times
  • 3 more comments
  • DavidCourt Feb 29, 2008
    Hello - I have the same problem. and the camera emits 3 loud bleeps - any ideas?
  • DeniseKiv Mar 14, 2008
    I have the exact same problem. Every other time I press the power button all I get is 3 beeps other than that - nothing. My brother said it's probably because it's just out of the warranty - typical. Please help
  • Hans302 Mar 16, 2008
    Another person here with the same problem - The camera is just over 1 year old - Tried new batteries etc - Still no joy - Just get the 3 beeps and the the camera powers down - Can't seem to find any support for this on the WEB? - Interested to see if there is a fix?
  • willirl Oct 07, 2008
    Same symptoms... get the beeps ... can pull out lens with finger nails but can't be doing the motor any good. This is the second time this is going back - warranty is one year not 2 I think but presumably I can argeue with PC World under the Consumer Act
  • Anonymous Mar 27, 2014
    Samsung digimax V700 will not turn on. fresh battery fully charged
This product has a 2 year warranty, unfortunately I lost the original till receipt, but managed to get the transaction details from PC World (I bought it in Dec 2006). The Samsung telephone number for the UK is 00800 12263727 - I have now sent it off to them for repair (recorded delivery) to the service centre at Samsung Opto-Electronics UK Ltd, Samsung House, 1000 Hillswood Drive, Hillswood Business Park, Chertsey, KT16 0PS - On talking to their service team, when the camera "Beeps" 3 times and turns off it is faulty, and will need to be repaired - So no easy fix - It's over to you now!!
Posted on Mar 24, 2008
This error is due to the lens mechanism being jammed and unable to extended, usually due to dirt or grit getting inside. The motor times out and the camera beeps 3 times before shutting down.
If you are unable to have Samsung fix this under warranty, you can carefully prise the lens out using a feeler gauge while powering the camera on, giving the motor a little help.
Posted on Jul 13, 2008
I have had my Digimax D103 since December 2006, and it has worked absolutely perfectly eveery time. However, just yesteerday, I turned the camera on, and the viewing screen was half the normal size, and in the bottom right hand corner, a kind of black fogg seemed to have appeared from nowhere. On trying to get the camera to work, the screen went black and displays nothing. It does still take pictures however, though you cannot see what you are framing!
Posted on May 04, 2008
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
Camera wont stay turned on
I had the same problem - found the answer on another forum: remove battery and memory card, press shutter button twice, replace battery and memory card, and switch on.
Nov 12, 2008 | Samsung Digimax i6 PMP Digital Camera
Buzzing sound
the problem is with lens.this sometimes happens if cam becomes victim with water.
there is some buzzing noise when the shutter of lens gets opened or closed.
please clean the lens with the solution once.then you can make out of blurs.
Apr 04, 2008 | Samsung Digimax S630 Digital Camera
Shutter does not open
The camera does not gets opened on power on it seems that some gear has broken inside
Feb 27, 2008 | Samsung Digimax A400 Digital Camera
Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
Nov 01, 2007 | Samsung Digimax S800 Digital Camera
Digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Feb 03, 2007 | Samsung Digimax i6 PMP Digital Camera
Samsung Digimax A7 Digital Camera Logo
431 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
