ZyXEL Ethernet Bridge Won't Connect
I have two ZyXEL G-470 wireless ethernet adapters (bridges) which I am trying to connect to a Linksys WRT54GS router running Tomato firmware. The first bridge (either one, doesn't matter) links fine. The second refuses to link, or links sporadically. I can only get it to stay linked if I attach a wired cable to its WAN port and enter the admin console. It then links immediately. However, after a few days, the link becomes sporadic again, and eventually both bridges lose their links. I contacted ZyXEL tech support but they couldn't re-create the problem (they didn't have a Linksys router to test with). I even got a third bridge and it does the same thing.
I suspect the router, although it supports every other wireless device on my nextwork (I have 4) without a problem. I have tried different configurations on the ZyXELs (MAC cloning, static IP, DHCP, only b or only g modes ... with no success.
Suggestions greatly appreciated.
  • philly100 Feb 19, 2008
    Thanks, but already tried different channels on the router, including channel 1. I think, though, that you are on the right track in seeing this as a router problem, because changing channels did improve (but did not eliminate) the problem. I know that the Tomato firmware still uses the Linksys kernel, meaning that (to my thinking) the problem lies inbedded in the Linksys software. Can anyone add to this?
  • 28 Answers
The i =ndications are quite clear it's a concern with router's wireless reception...try to reconfig wireless settings on your router change channel to 1 if still the same router is not sending wireless signals properly..
Posted on Feb 17, 2008
What does a red light for powerline activity mean?
It indicates your line quality for the Homeplug - Green: Best, Amber: Better, Red: Good
Details here
Jul 16, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
Can I use one wireless router to connect to my primary wireless router?
You wouldn't use a wireless router for the second device -- you would use a wireless bridge device. Most Wireless Access Points can be configured to be wireless bridge devices or you may be able to find a dedicated wireless bridge. Unfortunately, these devices usually have just one Ethernet port. That will mean that you'll need to buy an Ethernet switch in addition to the device that you're going to be using as a wireless bridge. This will add to your cost and make it so there is no real cost savings by using the Wireless Bridge + Ethernet switch combination.
If you can find a wireless bridge unit that has more than one Ethernet port, then you may be in business.
Using a second wireless router will not work unless the device has the ability to be configured to be a wireless bridge. Such routers are usually more expensive than your typical router, but you might get lucky and find one at a good price.
Good Luck
Feb 09, 2012 | Linksys Computers & Internet
I have a LG37LD490 and wish to conect it to the Internet. Is it better to connect via the LG Dongle or via an Ethernet bridge like the Linksys Wireless-N Ethernet Bridge with Dual-Band WET610N. My router...
i would suggest you connect via your ethernet bridge in your home network since the LG37LD490 comes with Wireless LAN for Broadband and DLNA. With the DLNA your television can join a home network of DLNA Certified™ devices, increasing the possibilities for sharing and enjoying your media right in the comfort of your living room or office.
Dec 05, 2010 | LG Televison & Video
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Linksys wireless g ethernet bridge I can't connect to the internet
if you have internet access with the modem straight to the jack do this:
;) if you dont have a connection in your modem try with a PPPoE connection ;)
Nov 12, 2009 | Linksys : WET54G Wireless-G Ethernet...
Can you help me please??
you need to setup a network bridge between the tower pc and the xbox 360
Select Control Panel/Network Connections and while hovering over Network Connections, right click and choose Open. This will open a panel that should list your network connections.
This image shows all my existing network connections. Yours may not have the same adapters. The two adapters that matter are your wireless adapter and your Ethernet adapter. They will have different names than mine because I have renamed them from their default values. I have highlighted the two adapters in the graphic below.
Step 2 If you have both Ethernet and wireless adapters (and you must in order for this to work), then both of them will be listed in the Network Connections panel. Using the ctrl-click selection method or the drag-area method, select both adapters.
Step 3 Right-click one of the adapters and select the Bridge Connections option.
Step 4 You will see a notification that the bridge is being built. This may take a few moments.
Step 5 Once the bridge is complete, you will see the bridge icon and the network adapters as shown below:
Step 6 The bridge is only partially complete at this point. To complete the configuration, you need to relate the network adapters to the bridge. I’m not exactly sure why this is because you have to select the adapters to create the bridge in the first place. This is my first bridge, so it’s possible there is a better way of doing it. But this process has worked for me. If you know of a more concise way of configuring the bridge, let me know and I’ll update the process.
In any case, select the bridge, right-click and select Properties:
Step 7 In the Properties dialog, put check marks in the network adapters that you want to bridge. Make sure you select the wireless and Ethernet adapters.
Step 8 Now, the bridge is complete. It will take a few moments for your laptop to finish the configuration, get a new DHCP lease and complete the connections.
To verify if your bridge works, connect the XBox 360 to your laptop’s Ethernet port and connect with XBox Live.
Dec 10, 2008 | Microsoft Xbox 360 Console
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Oct 10, 2008 | Toshiba WRC 1000 Wireless...
Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Computers & Internet Logo
320 people viewed this question
David Payne
David Payne
