Question about Brother IntelliFAX 1940CN Plain Paper Inkjet Fax
Brother Intellifax 2820
When making copies we keep getting document jams.
The "copy" is getting jammed in the drum unit. Any suggestions?
  • 159 Answers
Pull out the drum unit and try to rotate the drum using the gears.This will be hard, but persist and examine the drum surface, My guess is that there is residue from label stock adhering to the drum. You can try and remove it using Isopropynol and then polish it with car polish. This is an extreme measure, but the drum is shot otherwise. good luck
Posted on Feb 14, 2008
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 JAMMED
just clean paper path and clean all roolers and specially paper pick up mian jee
Dec 15, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jams continue to occur on brother fax 2820
Depends on the location of the jam is. Feed wheels need cleaning, clean with windex. or and most likely you have a bad drum unit,
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Intellifax 2820 plain paper fax
Take it out with the drum unit and make sure the toner is in the drum unit right. If it was ok before you changed the toner then you did something wrong. reinstall the drum and toner after you check it. Lawrence
May 01, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
check these locations carefully
1- where you feed the documents there is a sensor lever to detect a document, look carefully and push on it gently it should go back in place ( spring action)
2-before the drum there should be one
3- there is one in the fuser, YOU MUST look for the sensor usually after a jam a piece of paper is torn off and left on the sensor ( hopefully it was not broken off)
Jan 12, 2008 | Brother IntelliFax-2820 Laser Fax
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 1940CN Plain Paper Inkjet Fax Logo
95 people viewed this question
James Cagle
James Cagle
Jim Keysor
