Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Screen goes blank when I move the mouse
When the computer is on its fine.  The initial screen comes up with all our various names on.  I go to move the mouse to click on my name and the screen goes black.  If I turn off the screen again, it comes back on for a second or two until I move the mouse
my old dell 17" crt monitor recently quit working. I purchased a samsung Syncmaster 220wm wide secreen 22' monitor to replace it. It is connected to the computer through a Nvidia fx 5200 video card. The screen works fine on the loading screens but once the windows xp is loaded the screen goes blank if I move the mouse or try to open any programs. I have tried re-installing the drivers for the monitor and updateing the drivers for the video card. I have switched from digital cable to analog cable and back again, without any resolution. The only thing I can think of is thqt the resolution for this montior is somehow overppowering my older graphic card, but wondered if anyone else has had this problem before I replace the video card. I would hate to spend the money to buy a new video card only to find that it was a glitch in my mouser driver or some other softwaqre conflict.
  • drowingbear Feb 15, 2008
    dug the old montier out of the basement from another computer system. this montior seems to be functioing fine while the samsung is blinking off and on, and freezeing up when I try to move the mouse, could my video card be overheating?
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Posted on Mar 10, 2008
Did you try the computer with another monitor?
Posted on Feb 14, 2008
How to shut down a computer?
1. Close any applications you have running, such as your email or instant messaging service, by clicking the "X" in the upper-right corner of each program page.
2. Left-click your mouse on the Start button, typically found in the bottom-left corner of your computer screen.
3. Highlight the option to "Shut Down" and left-click your mouse again to initiate the proper shutdown process.
4. Wait until your computer logs you off of any applications, your computer screen goes blank and the power light turns off before you turn off your monitor or close your laptop.
Dec 23, 2010 | Computers & Internet
When computer is turned on the initial page vanishes the screen goes blank and the mouse arrow appears then sadly nothing just a dark screen !!!!!!!!!!!!
this problem might be due to the corruption of logon file
install a fresh copy of windows or try to restart it in safemode by pressing F8 repeatedly before boot screen.
Mar 30, 2010 | Acer Aspire One PC Notebook
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Green lights on front but nothing on screen
I have an E152FP and I was having the exact same problem...my fix was just to turn down the brightness below 60 and I have not had a problem since. Hope this helps...
Jul 27, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Screen on Toshiba M35x S149 Laptop blank/flickers
this can be caused by many reasons, here are some that comes to my mind: 1. bad connection between computer and screen, usually an easy one, but since its a laptop, you cannot change cable, so you will have to take it to the lab. anyway, if it is the problem, fixing it should be cheap. 2. in order to make sure it is "only" a faulty monitor, connect the laptop with another monitor, I dont know the exact function in this specific model, but as long as it has an video output, it can be done. 3. it is posible that backlight invertor has short circuit and should be replaced. this one can cost up to several hundred dollars, so be prepered. hope this helps.
Mar 30, 2006 | Toshiba Satellite M35X-S161 Notebook
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
2,706 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
