Question about Maxtor Hard Drive
2nd hard drive
When i look in my computer my second hard drive isnt there
    Champion:
  • 206 Answers
You Simply could have what is known as a partitioned hard drive and this will show up as two in My Computer, one is usaly the backup oporating system installed by the manufacture and the other ( C drive ) is the main drive, but they are both on one drive
Posted on Feb 13, 2008
  • 13,433 Answers
1. Make sure all cables are connected, does your bios detect the drive on startup?
2. Is the drive formated and set active?
to check if your windows sees the drive and is it active go to your desktop and right click on my computer -> manage -> Disk management.
You should see something like the picture below:
Your first disk will be Disk0 and 2nd disk will be Disk1 If you cant see Disk1 then the drive is faulty OR not connected properly make sure the drive is working with cables attached.
Listen if the drive spins. If it doesnt then something is wrong.
If you can see the drive there then you might not have made any partitions onto it. You can make new paritions to the disk right there, right click on your disk1(your 2nd hdd) and create a new partition. If that is not available initialize the disk with rightlick and blablaa .. I hope this solves it. :-)
Add a second hard drive to p6520f computer
if this were mine and I have done this too in the past.. is get a laptop/notebook hard drive which are considerably smaller .. look for an extra SATA connector from within your towers (located inside of course.. ) buy some Velcro and pretty much mount it where ever you want thus saving the aggravation about space issues
Jan 08, 2014 | HEWLETT-PACKARD Pavilion p6520f PC Desktop
I have a Dell Demension 3000... I have a hard drive in it that has XP as the OS... I am trying to install a second hard drive as a slave and I want to install Windows 7 on that hard drive. I wiped the 2nd...
yes it will show device is working properly
did you change jumper setting of your hard drive if not see the label top of you hard drive and change jumper to slave
Sep 11, 2010 | Maxtor Hard Drive
I got into my Coolmax external hard drive on my computer, via internet cable and router. I got into the hard dirve OK. I am trying to get another 2nd computer recognized on the hard drive. The Coolmax...
Indeed, it sounds like a sharing problem. But, based on your explanation, I'm not sure what your issue is as your terminology is not standardized.
Example: you said, "I am trying to get another 2nd computer recognized on the hard drive." What would be more accurate, is that you are trying to get the 2nd computer to recognize the 1st computer so you can access the 2nd computer's hard drive.
On the other hand, you said the hard drive uses a network interface, and you have it connected to the router. So does it have some kind of web based interface? No, if what I read about it says that it uses USB 2.0 and eSATA, which means it is directly connected to the 1st computer, and so it would have to be shared to the 2nd computer via the 1st computer.
I also note you don't specify any operating system, which is absolutely required. Because, for example: Windows 10 has sharing problems; I'm a professional, and I haven't bothered till they fix it.
You said: "I registered the ID and password", which does sound like you're using Windows to set up a share. But then you say, "Did Run //storage/person" which means nothing to me. As that's not any way to set up a share that I'm aware of. (Maybe I'll learn something ;-)) And then you say, "2nd computer's hard drive was not recognized" and that's confusing, because I thought you were trying to see the Coolmax which is on the 1st computer, right? Or is it on the 2nd computer. So it's really not clear what you're doing, or what you think you're trying to do. If you clear this up, I'd be happy to see what I could do to help.
How to set up File Sharing on Windows 10
Jul 04, 2017 | Coolmax HD-211-eSATA Hard Drive
Computer did not bootup after adding 2nd harddrive
Did you connect the drive to cable spot closest to the motherboard on the primary IDE channel? is it formatted? Did you try the drive on the Second IDE channel? Can your system support a 160 GIG drive?(if not try partitioning the drive.). Is the power and data cable connected properly?(the red line on the data cable should be closest to the power plug on the drive.)
Apr 11, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
Use second hard drive
The Windows operaring system is on your 1st drive (ie C drive) and if you change it to a slave drive the computer won't work.
You need to set the jumper on the 2nd hard drive as a slave drive and leave the original drive as the master drive expecially if the 2nd drive is on the same IDE controller and cable as the 1st. hard drive.
It doesn't matter if the 2nd drive is set to master or slave if it is on the 2nd controller.
When you boot up you should see both hard drives and can copy files from one drive to another.
Apr 08, 2009 | IBM ThinkPad R40 2681
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
I have a 600gd external Hard drive. I says its connected to the computer and its working, the light is on and everything and i can also hear it. But my computer isnt able to read it
have you formatted the drive yet?  If this is the first time you are using it, you have to format it.  If not, shut down the computer, unplug the USB and power cable from the hard drive...wait 2 minutes.  Plug the usb into the hard drive and the computer...then plug in the power cord to the hard drive.  Wait 30-45 seconds and then start your computer.  Hopefully that should fix your issues.
Feb 28, 2009 | Western Digital My Book Essential Edition...
Pc does not power on with hard drive plugged in
When you plug in the 2nd hard drive as a single drive does the drive spin up and the computer goes through the Power on self test (POST)?
If you cannot hear the drive spin up and the computer doesn't boot up then most likely the hard drive is faulty.
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Screen dies when booting up
TRY PLUGGING IN EXTERNAL MONITOR, THIS IS IF YOU HAVE A LABTOP AND I THINK NOT.
HOW ABOUT REMOVING THE OLD DRIVE AND PUTING IT ON THE NEW COMPUTER AS 2ND DRIVER OR SLAVE DRIVE, SOME COMPUTER CABLES OFFER SELLECT CABLE THE C DRIVE WOULD BE 0 AND 2ND DRIVE WOULD BE 1, IF YOU DONT HAVE SELECT CABLE THAN EACH DRIVE HAS TO BE SET UP YOU WILL HAVE TO GO TO THE MFG WEB SITE LOOK UP JUMPER SETTINGS, THE FIRST DRIVE WILL BE THE MASTER AND THE SECOND ONE WILL BE THE SLAVE, NOW IF YOUR CD ROM IS ON WITH THE HD THAN YOU WILL HAVE TO HAVE 2ND CABLE FOR THE CDROM TOPUT ON THE 2ND SET OF PINS MARKED 2ND HD OPTION AND YOU HARD DRIVERS MASTER AND SLAVE GO ON
BANK 0 IF IT SAYS 0, IF IT SAY1 THAN PUT IT ON 1.
REBOOT AND THE COMPUTER WILL START AND PUT YOU INTO THE CMOS AND YOU WILL ADD THE HARD DRIVE BY GOING TO 2ND HD PUTTING CYCL, HDS, SECT, YES LBA
2ND CABLE YOU SELECT CD OR DVD
F10 AND YES
REBOOT
EVERYTHING SHOULD WORK FINE.
IF YOU DONT FILL CONFERTIBLE DOING THIS TYPE OF INSTALLATION THAN HAVE YOUR COMPUTER PROGRAMER FRIEND DO IT FOR YOU OR COMPUTER TECHN WILL WORK TOO.
ROD
Jan 20, 2009 | Nvidia Riva TNT2 16 MB Graphic Card
WD not turning
First enable the hard drive in bios if you havent already .Then if you have windows xp click right on my computer and select manage,it opens up computer mangement, then go to the tab called storage and on the sub menu of storage click disk management . You should see you 2nd/other hard drive (labelled disk 1 at the bottom if it is the second hard drive) make sure its your 2nd HDD ( Look at capacity in properties by clicking right on it) .Click right on the 2nd hard drive and select format press ok when the new window comes up and its finished.
Nov 15, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Maxtor Hard Drive Logo
95 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
