Question about Vacuums
Eureka whirlwing vacumn- upright
I took an air compressor, blowed it out, it's bagless, motor has loud noise, will not suck air through hose, very loud
    President:
  • 1,673 Answers
You may have a clog in the hose or the inlet by the brush roll. If they are clear, then the nosie may be coming from your motor and will have to be replaced.
Posted on Feb 14, 2008
Motor loud
The beeter bar bearings are bad i just changed the beeter bar on a vacuum that fixed the loud noise check for play in the old beeter bar brush
Mar 21, 2014 | Eureka 4700A Maxima Bagless Upright Vacuum
How can I use my upright as air compressor to inflate air mattress
It would be difficult because your upright does not have an exhaust port where you can hook up a hose. You would have to attempt to funnel the air from the exhaust filter into a hose or tube.
Mar 08, 2014 | Eureka Boss SuperLite Bagless Upright...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
The vacuum is blowing out a lot of air, doesn't ****
make sure the dirt cup is empty and the filter cleaned .. once the filter is clogged it wont work ...make sure everything is assembled correctly to seal the cup ... this nice little vacuum should work good except on deep carpet ..
Sep 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Kicking out debris
Your vacuum will kick back dirt if there is a clog of anykind, or if the filters are dirty. First check the suction lines for any clogs, if none are found, take out your dirt cup, and take off the filters. Normally there is a foam prefilter covering a paper filter - replace both filters. The reason this happens, is that the filters allow the air flow at a specific rate, creating the suction and they cyclonic action you see when you are picking up debris. I hope this helps.
Jan 20, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
No suction.
Mine is doing the same thing, the hose picks up things fine but the rollers turn and instead of picking up it is blowing air out????
Nov 29, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Accessory hose not sucking
Try taking the hose off, and making sure it is not stopped up, either in the hose, or where it attaches. Straighten a wire coat hanger and run down the hose to check for obstructions.
Hope this helps!!!
chad
Oct 08, 2008 | Dyson DC14 All floors Bagless Upright...
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
166 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
