Question about Brother SE-270D Computerized Sewing Machine
I have a Brother Sewing Machine #NV1500D/V1500- I cannot get my patterns for the Lrg hoople to rotateso the design is staight up. I Please do not tell me to call my slleer as I asn hungup on him he
Brother>Disney > SE-270D Blanche Marion Virginia Beach,VA bmarion1@cox.net
    Genius:
  • 3,587 Answers
Here's the link for the manual, if you don't have it.
get the adobe reader first here.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SE_270D_EN_199.PDF
Posted on Feb 17, 2008
Brother embroidery machine has started shifting design outline between first colour and others, about 1/2 inch can't back up to correct starting point, doesn't respond.
Did it do this on more than one pattern? Has it stitched this pattern before correctly ? You can try turning the machine off and back on and let it reset. If it is only doing it with this pattern and it's the first time you have stitched it , try again after turning the machine off and back on. If it's not doing it to other patterns and you bought the pattern contact who you bought it from as there is a flaw in the design. Have them check and resend it. I have a converter program so if you get it in a different format you can change it to your format. Sometimes it is designed on a different machine and did not convert well. When I have this problem I download it in .hus and convert it for brother. There are several free preview programs that show you the design and stitch order and let you save it to different formats. If this isn't the problem I would call brother USA +1-877-276-8437
https://maps.google.com/maps?oe=UTF-8&hl=en-us&client=safari&um=1&ie=UTF-8&fb=1&gl=us&entry=s&sa=X&ftid=0x887f76273cf4c67b:0xf6ed103a13e50c19&gmm=CgIgAQ%3D%3D this is in TN. And open 24 hr. And explain to them what it is doing.
Mar 18, 2017 | Brother Sewing Machines
I have a USB flash drive with one pattern on it that I use often. Tonight, my machine won't read the pattern. I click on it, it says "wait while retreiving pattern", but nothing happens.
Hey Diane, THis is a guess but try deleteing some designs off of the machine's memory. I have a feeling it's small memory is full and can't accept or read any more designs until some room is made.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Jun 26, 2015 | Brother PE770 Computerized Sewing Machine
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Aug 22, 2014 | Brother SE400 Computerized Embroidery and...
Hai, What type of your embroidery machine? How many heads and needles? If your machine 4 ,12 or 20 heads and 6 or 9 needle, you can use different color and designs.
Apr 10, 2014 | Brother Sewing Machines
A high pitched sound comes out of machine when inserting card.
I'm new to embroidering and mine did the same thing a few weeks ago. I discovered the buzzing sound was because the design I saved to the card was too large. I decreased the size and the design worked perfectly.
May 18, 2013 | Brother PE-150V Computerized Sewing...
I need to rotate my pattern by 45 degrees on my brother pe 770. I've tried going to layout but it only does 180. Any ideas?
Get software such as Embird Design to do it and then export the .PES file and transfer to the machine. Unfortunately the low end machines do not have this capability.
Apr 02, 2013 | Brother PE770 Computerized Sewing Machine
Brother xr-36 sticthes skip when using design / pattern
what fabric your sewing on like cotton you would use a different
needle than if you were sewing on stretch fabric.
it's also possible that a gear or decorative cam may be worn or
damaged, having the machine checked at a repair shop would
be a good idea
Nov 01, 2012 | Brother Sewing Machines
Brother 4000D does not sew out patterns correctly and sometimes jams.The designs are sewn with parts missing or in wrong position. I have tried the same patterns on my Pfaff and no problems but my 4000D...
Try sewing instead of the embroidery feature.
If the stitching is messy, the machine needs to go into the shop for service by an authorized Brother dealer as the timing needs to be adjusted. Take a sample of the problem with you.
Apr 03, 2010 | Brother Disney PE-400D Computerized Sewing...
Can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.   Cheers, Ginny
Ch
Dec 10, 2008 | Brother Disney PE-400D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
142 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
