Question about Metz 44 AF-4N TTL Flash
D200 compatibility ?
Hi, any idea if the flash would not work with D200 in TTL mode??????? I just bought one and it doesn't - so not sure where the problem may lie....
cheers.
  • bazancik Feb 13, 2008
    checked both the fit and the pins- all in perfect order... the strange thing is that in TTL mode the camera would not fire up at all (blinking Flash sign on the display and in the viewfinder). It works in manual mode. Also in options no no Auto zoom option - can only select manual zoom.
  • bazancik Mar 02, 2008
    the flash would not work in ttl mode (cannot shoot - blinking FLASH control light in viewfinder)
    any suggestions??????
    cheers
  • 667 Answers
Metz says yes: Metz
Certainly Nikon will say no. I would double check the fit of the shoe on the camera. The pins on the flash should be springy to the touch.
Posted on Feb 13, 2008
Not sure what i need to use the mecablitz 60 ct-4 w/ my Nikon d-100
I just bought a D100 (as a backup to a D200 - nothing like being up to date with current technology! B^)). As I understand it, there is no integral flash sync connector on them. You need to get an AS-15 accessory shoe adaptor which goes on the hot shoe, and has a pc sync connector (like the D200 has on the side of the main body). Then you use a standard Metz sync cable to attach to that. The Metz 60 CT flashes have a low voltage trigger circuit and so should be safe with any camera.
Jul 10, 2011 | Metz Mecablitz 60CT4 TTL Flash
SB-800 Stuck in REMOTE
http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
Running in TTL mode with Nikon D200, flash EF-500 DG ST NAd, doesn't work. In manual mode everything runs well.
this flash is not compatible with the d200. i had one and sent it back to sigma, they upgraded the software in the flash for free. now it works in all modes, it needs to be iTTL to work on the nikon d200 the NAd version is not iTTL.
Jan 01, 2011 | Sigma EF-500 DG ST for Nikon Flash
I am using a nikon D200 with a sb800. The flash is firing ok on TTL and the camera is set on 'P' however I am getting a dark picture every tme. The built in flash works OK It appears the flash/camera...
This is an excellent flash, very powerful and compact and actually more flash then what was available when the D200 first cam on the market. The two will work nicely together and I think the problem is that the SB-800 can be programmed within itself. This meaning with some cameras you program the camera for the flash output with the SB-800 you can program the flash as well. It has some excellent features like Flash value lock (which I think is set to slightly underexpose from what your question is asking) it also has Flash color information and a built in Flash compensation. Possibly the compensation or value lock are set to underexposure. I'm saying this over the camera setting because you stated that the internal flash appeared to be okay, check your SB-800 settings
Dec 27, 2010 | Nikon Speedlight SB-800 TTL Flash
Sigma ef-500 dg st won't work with my d300 or 200 in ttl mode
This Sigma flash is not Ittl compatible. The D300 and D200 Nikon must have Ittl compatible flash to operate in any of the Automatic modes. It is a great flash but will not work on those two cameras.
Dec 14, 2010 | Sigma EF-500 DG ST for Nikon Flash
I've had 2 Metz 54MZ4 flash units with my Canon 1Ds and 10D cameras and none of them work in TTL mode. They give full output power in TTL. What is problem?
If your Metz is for Nikon it will not work in TTL on Cannons. Metz makes different flashes for Nikon and Cannon. I have a Metz 54 that I use with my Nikon D200 and it works as well or better than the NIkon SB800 in TTL.
Jun 04, 2010 | Metz 54 MZ-4 for Nikon TTL Flash
Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Vivitar 636 and Nikon D200
You won't be able to use older TTL flashguns with the D200. Since the D70, all nikon cameras have used "iTTL", and earlier DSLRs (eg D100) have used "D-TTL". Neither of these are compatible with the older TTL system used on film cameras. The newer SB-400/600/800 flashguns are all ok, and Sigma and Metz both produce iTTL compatible flashguns. The new flashguns will work on old cameras but not vice versa.
I know this is annoying, but there were good technical reasons why Nikon changed the TTL standards.
If the 636 has an A mode (non TTL) this should work ok, otherwise it will only work in manual (if it has a manual mode).
Oct 25, 2007 | Nikon D200 Digital Camera with 18-200mm...
Wont work
According to the Canon feature chart I have here; the 540EZ Speedlite flash is not compatible with the Digital Rebel XT in ETTL mode. The 480EG is also not compatible. The 550 or any of the others in that product line are would work. David Millier Advance Camera Repair
Feb 26, 2007 | Canon Speedlite 540EZ TTL Flash
Metz 44 AF-4N TTL Flash Logo
108 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
