Question about DeLonghi EW0507 Oil Filled Radiator Heater
Delonghi "The Incredible Heat Machine"
I have been using a DeLonghi "The Incredible Heat Machine" oil filled heater with no problems until a couple of days ago. A few minutes after I turned it on, I heard this crackle/pop sound, kinda like a sizzle of hot grease/oil. I used it that night coz it was below 0o degrees out but I was and still am paranoid that this is going to cause a fire. Do you know what could be going on? Is it safe to use? Can it be fixed? It's been effective in warming up the room but I'd like to know more before I continue to use it. Thanks
  • butch 1234 Apr 02, 2008
    yeah same problem but now mine causes the house fuse to blow after its been on a few minutes
Blows the house fuse after being on a few minutes
Posted on Apr 02, 2008
POWER IS ON--LIGHT ON, BUT DOES NOT HEAT UP
Check to see if the heating element has continuity or if it is even receiving power.
Mar 05, 2016 | DeLonghi TRD0715T Oil Filled Radiator...
I inherited this heater with no manual and am in need of some instructions on how to properly use it and how to set temperature etc.
Go to Delonghi web site http://www.delonghi.com/ select country you are in. Select Customer servivices and then Down load instruction manuals. Hope this helps.
Aug 09, 2010 | DeLonghi TRN1015T Solaris Oil-Filled...
Won't heat
Try calling delonghi america at 1800 322 3848
Dec 14, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Jan 28, 2008 | Heating & Cooling
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Open Questions:
See all DeLonghi EW0507 Oil Filled Radiator Heater Questions
DeLonghi EW0507 Oil Filled Radiator Heater Logo
2,335 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
