Question about 2wire (1000-400108-001) Router
WIRELESS CONNECTION FINDS NO ACCESS POINT.HAVE LINKS NOTEBOOK ADAPTER WORELESS 3. CONNECTIVITY IS NOT CONSISTENT.
QUESTION 2. i ALSO HAVE AN IPHONE IT ASKS FOR PASS WORD FOR WIRELESS CONNECTION. hOW DO I RETRIVE MY PASS WORD FROM LINKSY?
  • Jim Gogs Feb 16, 2008
    I purchased an IPOD touch and it finds my 2wire signal but then asks
    for my password. How can I get my password?
  • Cara1 Apr 05, 2008
    I didn't even know there was a password until I called TIVO support when I called to activate my new TIVO HD. I wanted to connect to broadband. I have a 2 wire home portal and don't know where to begin.
    Christine
Type in the name of your router followed by "IP" into google. For example "linksys router IP".
Then log into it (the name and password are usually default e.g. admin admin).
The passwork key should be there somewhere
Posted on Mar 11, 2008
  • 19,396 Answers
If you mean the encription key, which technically is not a password, you may get it acessing to the router page with Internet Explorer. You will need your router's IP and a wired connection.
hope it helps
cheers
Posted on Feb 13, 2008
I configure a DAP-1150 and can connect via a laptop but my iphone and ipad fail to connect it. However, when I reset the DAP (with no security), the opposite happens! It means that my iphone and ipad can...
That is because your laptop has the saved connection history that you need to delete. Since your acces point does not have security which is not the same as the one that saved from your laptop. Therefore, your laptop won't be able to connect. Go to network and sharing center and from the left side of the page that came up look for change wireless adapter settings and click it. You will be able to see the connections that was saved and the top one would be your connection name. Delete that and close everything. Try connecting to your wireless network again and that should resolve the issue.
Feb 06, 2013 | D-Link DAP-1150 802.11g Wireless Access...
Please tell me step by step how to connect internet worelessly with usb adapter 2.0. thanks
Connect the USB adapter into ur Laptop
After the Laptop detects the device it will look for the device driver. Cancel the setup at that point.
Go to My computer , open the external drive and click on the setup.exe icon.
It will automaticaly install all the required things.
Dec 04, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I can pick up a linksys access point, but it will not let me connect to the internet. I do not have the original set up disk.
Do you own the access point?
If not, are you authorized to use it?
Access Points can be configured to _only_ grant Internet access to _specific_ wireless adapters.
(Each wireless adapter has a unique 12-character code.) So, if your code is not on its "accept" list, you won't be able to connect.
Jun 15, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
I can connect to the access point but it will not let me connect to the internet.
If so, after connecting/authenticating to it, start Internet Explorer, and access the web-server "inside" the access point. Click to select the 'WAN' settings, and confirm that the access point is getting an IP-address from the Internet.
Cannot connect to access point
Are you using the Linksys utility to connect to the wireless network?
If you are using that then you can switch over to windows utility.
It is very simple to connect to the wireless network.
Click Here for More info
Oct 07, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Connecting to woreless internet connection
Be sure you use same security protocol on your PC than in your WLAN:
WEP or WPA or WPA2 protocol
Passphrase (PSK ) or Password
TKIP or AES.
Use same Key.Passphrase on your notebook as in your Access point.
Check if your Access point/router has access list enabled: either you disable it in your AP either you add your PC MAC address to the list.
Dec 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Need help
Try typing 192.168.1.1 into your browser. That is usually the default address used by most routers and such. If that does not work then find an open source network scanner like Nmap and run it to determine the IP and then type it into your web browser. Word of caution these tools are for experts.
Nov 26, 2007 | OTC ACR201-G (00CSPP000122) 802.11b/g...
2wire (1000-400108-001) Router Logo
105 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
