Digital broadcast compatible
Is my TV going to need a digital converter box?
  • Mike Owens
    Mike Owens May 11, 2010
    First we need to know what type and model number of your set, But if you are already hooked to cable you are good to go. or go to www.dtvtransition.org to find out more
WILL MY MEMOREX MVDT2002B TELEVISION NEED A DIGITAL CONVERTER BOX?
Posted on Jan 19, 2009
I have a 1999 RCA TV model # F27645. I wanted to know if I am going to need to get a digital converter box?
Posted on Jun 04, 2008
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
How do i tune in my digital cable on my analog tv?
You'll need a digital cable box for that, I'm afraid. The analog tuner in the set isn't compatible with the digital cable signal. The cable company in my city just dropped their analog service. Now you either need a digital converter box, or a "cable box lite" called a digital transport adapter. For digital off-the-air broadcasting you need a digital tuner and probably an amplified or outdoor antenna. The analog TV is rapidly becoming pretty useless except as a display device as analog channels disappear.
Mar 11, 2010 | Curtis-Mathis CM19011 TV
My tv won't pick up all channels since going digital. says signal is 62 percent. we have an arial extension could this be the problem.
If you live in the United States it is a problem since going digital. Analog signals are not broadcast anymore and your antenna is designed for analog signal, not digital. Now that the DTV Transition is completed, analog TV sets need additional equipment -– a digital-to-analog converter box –- to receive over-the-air television. Analog sets equipped with a converter box will display the digital broadcasts, but not in full digital quality. The box can be purchased almost everywhere. I hope this helps and good luck!
Nov 11, 2009 | Televison & Video
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
May 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
1992 LXI TV AND THE CHANGE TO DIGITAL
You should be fine. Direct TV advertises that they are already broadcasting in full digital. So your box or DVR will act as that converter.
Mar 14, 2008 | Televison & Video
HDTV COMPATABLE
the hd sat box is your converter and is compatible to your tv (1080i only). if you are asking about local braodcast (over the air) this set doesn't have an ATSC (digital) tuner so you would need a box for that. but your sat company may be giving you your local broadcast in HD.
so if you are presently using an aeral antenna for your locals yes you will need the box.
if your locals are already being supplied by your sat company no the sat box is your converter.
note: some sat boxes have ATSC tuners built in so your antenna can be used by the sat box as well.
Feb 29, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
