Question about Kenmore Elite 45986 Front Load Washer
Keep getting ht code ,and it wont let us use the rinse
We read the manual it said change hose ,we did.and it still wont work all the way.can anyone help us,you see we have just been having crap,after crap go wrong,we just are at are witts end!
  • 1,314 Answers
Take the hose off and check the screen on the water valvemake sur its not clogged and make sure the hot hose is commected to the h terminal on the washer and the cold hose is on c and advise
Posted on Feb 13, 2008
My washer wont rinse or spin and when its finished washing it gets to rinse cycle and beeps and error code e4 comes up i emptied clothes and it still wont work
No make or model came through with your question... so the FIRST GUESS... is ... THIS IS A NEW RELATIONSHIP with a "HE" (HIGH EFFIEIENCY) washing machine.
You can CONTAMINATE your machine quite badly by not using THE RECOMMENDED "HE" rated detergents... & CLEANERS.
These new machines will rapidly deteriorate in performance... if the APPROPRIATE (HE) detergents ARE NOT USED.
Sensors sample the detergent/dirt in the water to enable the wash cycle to adjust wash time & water levels...
By NOT FOLLOWING the INSTRUCTIONS you are risking PERMANANT DAMAGE to these sensors...
Read your OWNERS MANUAL... There-in (I believe you will find
HE cleaners (not cheap) are recommended to ATTEMPT to restore performance...
Else you are looking at an EXPENSIVE SERVICE CALL on a NEW MACHINE.. Who knows... MAYBE it will be covered under your WARRANTY... Stranger things have happened (these days).
Good luck with that.
affresh WASHER CLEANER 3 Tablet Odor Remover Clean ANY Washing Machine...
Amazon co uk washing machine cleaner
Jul 16, 2016 | Washing Machines
Overheating wont start
could be one of many things , i'd start with getting the OBD codes read and then work out why its overheating , is the water pump working ,if the top rad hose gets hot and the bottom rad hose is a lot cooler then there's more than a good chance the water pump isn't working , do you have to keep topping up the coolant ?keep me posted if you wish
Jul 19, 2014 | 1998 Oldsmobile Intrigue
Code f33I got this error code so I cut electricity on the washer completely and waited about an hour to put it back. Then I tried to do a drain/spin cycle as I read somewhere, the washer is spinning and...
usually the result of clogged hoses line or impeded water pump propeller? you have to check the hoses and pump manually , see if u can turn the water pump by hand
Jul 14, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarious WF630 error code H20. It will fill and wash with both hot and cold water but when it gets to rinse and spin the error code flashes. It will however spin if i manually change the...
H20 does in fact indicate a problem with the incoming water supply.
Check the inlet hoses/s to make sure they are not kinked or restricted in anyway, more so when the washer is pushed back.#
Make sure tap/s are fully turned on, make sure you have good water pressure.
It would also be a good idea to check the gauze filters in the inlet to the valve/s.
Feb 08, 2010 | Washing Machines
Dvd player wont play burned movies
most of the movie if download from the net protected my different formating keeping people from burning and selling coppies. as long as your dvd play dvd is working fine. I got lots of those downloaded movies from a friend myself some play and some dont. I bet you if you go through most of your copy dvd some will play and some dont. Your sysytem may read some dvd VS mine may read some of your's that you system dont reads, you will not find a unit" DVD" will deformat the protection copy rights. I have 850.00 unit almost top of the line still wont read lots of copy DVD.
Jun 04, 2009 | Samsung HT-DB600 System
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Our Smart Drive 601 wont rinse or spin properly and keeps changing its own settings and pauses
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve.
May 30, 2008 | Frigidaire Washing Machines
MP3 CD's Not working Samsung HT-DB120 System ?!!!
Try opening the zoning code. Unit must be switched on with NO disc inside. press enter,then enter the code 84269 and press enter again.unit will switch off. switch on unit and try again.
Feb 12, 2007 | Samsung HT-DB120 System
Kenmore Elite 45986 Front Load Washer Logo
91 people viewed this question
Sal De
 Brian Main
Brian Main
