Question about Canon PC1061 Copier
Copies paper great except leaves a long invisible 1 inch thick line down the middle
My PC1061 copies great and fast but last week it started leaving one long one inch thick line from the top of the page to the bottem. Maybe like theirs something stuck in front of the scanner light???
  • tommyking Mar 04, 2008
    I purchased a new cartridge & it still making that one long line down the middle of the paper...any more advice
  • 552 Answers
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Posted on Feb 13, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Mar 04, 2008
    http://www.precisionroller.com/find/cano...
    this is the website that will help the most.
    You will find a service manual there.
    Also, many parts that you may need.
    You may want to look at the transfer roller in your machine.
    If it has worn, ther may be uneven transfer.
    There could also be a problem with the laser control.
    This website has a number to call and they should bew able to tell you what to look at.
Solid lines varying in with
When you copy? or when you print? If print OK check the doc feeder
Nov 11, 2013 | Minolta MF1600E Plain Paper Laser Fax
Lexmark E120. When it prints it leaves a thick black smudge about 1/2-1 inch thick down the entire left side of the paper in waves. Is there away to clean something or replace something to correct this?
It's time to take your printer to a professional technician, to trouble-shoot and fix this problem,
if you don't know how to do this by yourself.
Jul 30, 2011 | Lexmark E120n Laser Printer
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
When you run a copy it leaves a couple thick dark lines on the paper that you copied too.
If you lighten the exposure do the lines fade away ? It most likly needs a drum or a drum cleaning blade. Good luck.
Jul 14, 2011 | Sharp AR-162S Copier
A thick line in the middle of the paper is coming on the xerox copies
If the line goes to the very edge of the copy its the fuser or drum if there is a line that leaves a 1/4 inch to the edge of the copy then its in the optics. -Carl
Aug 10, 2010 | Ricoh Aficio 2015 Copier
Copy is printiny a shadow of the document also.
check your printer head try to clean or clean it..
any further question let me know ok..
thanks,
Mar 16, 2009 | Canon PC1061 Copier
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
WHEN YOU SEND A FAX IT LEAVES A LINE HALF INCH BLANK DOWN THE RIG
Does it also leave the line when you make a copy? Lift the lid and make a copy cover up. If it is there on the copy then most likely your scanner needs to be cleaned. If it isnt there when you copy, let me know we will go from there.
Dec 08, 2008 | Xerox WorkCentre M15i Laser Printer
Leaves about a 1/4 inch space down middle of paper.
That is the cleaning assembly in the drum cartridge.Either something slipped into the cartridge or the blade tucked. Sounds more like something is in the cartridge blocking the drum from both cleaning and charging/
Mar 05, 2008 | Sharp AL 1631 Copier
Canon PC1061 Copier Logo
152 people viewed this question
old marine
old marine
