Question about Samsung Digimax S800 Digital Camera
Samsung S800 When I turn on my Samsung S800 the indicator lights flash on then off then I hear 3 beeps and the camera fails to turn on?
  • 14 more comments
  • Blue1878 Feb 14, 2008
    Worked first time. Thanks for the great advice.
  • Anonymous Apr 14, 2008
    my camera lens i believe is stuck. my camera will turn on but dah vision when it turns on is blurry and then it beeps 3 times and turns back off. dah lens is extended as well
  • Anonymous Apr 15, 2008
  • Anonymous Apr 19, 2008
    i switch the camera on then 3 beeps and it turn off.i have check the baterries but this is ok
  • broge001 May 25, 2008
    my samsund digimax s800 will not power up, i turn it on and all i get is 3 bleeps then it powers off. doe's anyone know how to fix this problem.
  • MUGAD May 29, 2008
    My camera has the zoom lense out. I replaced the batteries, but it beeps twice and nothing happens. There shutter lense does not retract back into the camera, no does it show any previews. its just beeps and thats the end of the story.
  • Anonymous Jun 01, 2008
    Enciendo la camara sale en la pantalla samsung luego los tres pitios y luego se apaga y no entro mas el lente y quedo afuera hasta que la lleve al tecnico y no puede hacer nada.
  • nbossert Jun 19, 2008
    I have the same problem. So, I tried the solution. I managed to get the lens to come out, and the camera worked fine to take a picture. Then I pressed power to turn it off, and it got stuck while retracting. Now I have the same problem again. I think I got some sand in it at the beach. Is there a way I can take the lens out and clean any sand off? I tried compressed air, but it doesn't do the job.
  • heidijens1 Jun 23, 2008
    I have the same problem of it giving three beep then turning off also the lens is stuck out. I tried the solution posted here and it did not work.
  • woolyhead Jun 28, 2008
    Yup, same problem... only the lens is stuck just a little way out, so I can't get enough of a grip on it to pull. Pushing it in doesn't help either.
  • jonny24 Jul 12, 2008
    camera turning on then turning off...it makes a beeping sound whilst turning on to off. No picture displayed at all even with new batteries
  • rw-abz Jul 29, 2008
    exactly the same as Blue1878,s problem
  • jokerville2 Aug 16, 2008
    same exact issue - probably a defect in the camera . I am thinking of returning it since it is within the 30 days and I never dropped it or had any other reason to cause this to happen . I do change the batteries and then it powers on but that is a hassle and should not be happening .
  • lainie239 Sep 22, 2008
    I have the same problem, carried out the solution and it worked, yeah!
    Ta
  • SING82757 Oct 12, 2008
    BEEPS 3 TIMES THEN SHUTS OFF.
  • Anonymous Jan 12, 2009
    I have the same problem and I know that its dirt in the zoom lens because it started when i powerd off the camera and now it just got worst. I have to pull them out with my and as soon as i power the camera, but when it try to focus something it just shut´s off due to the effort. How to clean (open?) the damn thing is the issue?
    Problem Solver:
  • 6 Answers
My camera powered on then off so i took it apart, I found the cogs that move the lens in and out were not meshing together so I manually moved the lens all the way out, then I put the pins that were holding the cogs into allignment with each other and It worked.
Posted on Feb 24, 2009
Ye ha good stuff thanks 4 that solution
Posted on Oct 08, 2008
I have the same problem Having forced the lens out, it retracts when I power off and back to square one. My solution is to force the lens out (was horrible grating sound) and then power off by opening the battery door. The lens stays out when you power on again and it still takes good pictures. Not ideal but better than a new camera.
Posted on Jul 13, 2008
Who ever previously posted this answer is THE MAN....
All I did was gently pull on my lens and reinstalled new batteries (Just in Case).
Then I powered on the camera and eveything worked Fine. Not sure what caused it to happen in the first place but very greatfull everything is working again.
Great Site for help.......Thanks
Posted on Feb 25, 2008
  • 20 Answers
Lens mechanism can be stuck. Try gently to drag or straighten it.
Posted on Feb 13, 2008
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
My s800 camera wont turn on or it does but the zoom/lens is stuck and wont come out-it then has 3 beeps and turns off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 20, 2011 | Samsung Digimax S800 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
S800 lens won't close, can't take photos
The lens was bent to one side, so bump with my palm to straighten it back. I was able to start using my Samsung again.
Mar 21, 2009 | Samsung Digimax 800K Digital Camera
Samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Dec 20, 2008 | Samsung Digimax S800 Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Samsung S800
If the camera fell on it's lens it is probably jammed. Try to find something small, strong and thin, possibly a hairpin and slide it into the barrel while gently trying to force it outwards immediately after switching it on. When it does extend, try to clean or blow out any grit that may be inside the mechanism. The batteries are hot as your camera does not switch off and may be remain on for hours
Feb 23, 2008 | Samsung Digimax S800 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
3 beeps and nothing else
just three months old?- return it to the Vendor for replacement and get onto the Samsung Tech support Team
Jul 10, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
228 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
