Question about Refrigerators
Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
About 3 weeks ago my icemaker started making some peculiar noises and stopped producing ice. I pulled out the entire ice bin and felt around inside the ice maker area to see if frost was blocking anything or if I could feel somethin amiss. I found nothing out of the ordinary.
I popped up the ice maker arm for 24 hours and then releases it back to the lowered position, which is where it needs to be to make ice and nothin has happened.
I get water from the dispenser in the door but I do not hear the filler making any noise inside the icemaker and I used to. I dont think the mechanism which pushes the cubes out is working either.
What can I do?
  • jlieber Mar 05, 2008
    I am having the same problem. I do not have water going to the ice maker but I do have water to the door. I filled the ice tray in the freezer last night to see if it would dispense the cubes but it has not.
    President:
  • 1,314 Answers
Reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
Posted on Feb 13, 2008
Make sure the water inlet pipe is frozen, take the screw off the back and run warm water through the pipe to make sure you are getting water through.
Posted on Jun 19, 2009
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice
there is a separate solenoid that controls the icemaker its on the back of the fridge on the bottom.
it may have stopped working or the filter is clogged.
its a simple fix but it takes some know how to do so.
Mar 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker noise and malfunction
on the back wall just above or under the fill tube youl find the wire harness , simply unplug the ice maker, while your at it 3 1/4 screws mount the ice maker to the side wall, youll have more room in freezer by removing it
Feb 19, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
629 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
