Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint ultima switched on power and have nothing to washing machine
We want electric circuit diagram of the machine
Posted on Feb 25, 2009
The code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Posted on Apr 13, 2008
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
Washing machine motor not turning
hello,
what this indicate is that there have been a power disconnection from power supply on the jet string connected to the drum (drum controller)
what you will have to do to solve this problem is to unscrew the the washer then trace the wire down to the jet it is round in shape at the back of the washer
please rate this
thank you
Jul 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima baby icon flashes/beeps
the icon means that the child lock is on.
if you switch on the power to the appliance and hold down the child lock button untill the icon disapears the you will be able to select a program.
Apr 15, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
227 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
