Question about MSI L730 Notebook
Lan network connection
Msi laptop lan connection stoped working- as if disconnected
  • yanai Feb 15, 2008
    no that is not it, I tired two different cables....
  • ditee May 29, 2008
    I have got the laptop one month back. When I plug on the cable to have a LAn connection, my laptop does not show the LAN icon and in the network place too LAN does not come up. I have Windows XP.
  • 44 Answers
    Sergeant:
    Champion:
  • 243 Answers
First thing to do is to try a different cable. I pressume that it hasnt been disabled in network connections by mistake?
Posted on Feb 13, 2008
Can not connect to network except through wireless
I suggest that you go to the device manager and reinstall the driver for your LAN. If you don't know how to do this or if you want to go for the easier way, then I suggest that you use RadarSYnc.
David
Jul 26, 2013 | MSI NB i5-480M/4GB/500GB/DVD/14/W7P...
My MSI wind U140 not detect my ethernet after installing windows 7 ultimate lite version
Go to the MSI web site & download the LAN drivers.
Which will be under the support tab, then select your make & model of PC.
then select the OS you have installed (in your case windows 7 ultimate)
download & install.
Jan 30, 2012 | Computers & Internet
With my msi wind i can't seem to connect to my wireless network. what can be the problem
you mite not probably have installed the wireless lan driver if installed check for the correct network authentication... if everything is good then check with your inbuilt wireless devise it mite have some problem...
Jul 30, 2009 | MSI Wind UmNotebook
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Can't get it to connect to wireless
From User manual you can download from HERE:
1) activate your WLAN :
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function recurrently.
2) Check if "Wireless LAN LED indicator glows green when Wireless LAN function is enabled."
3 ) Use Windows to configure your Wlan.
Let me know if you need more help.
Dec 29, 2008 | MSI Wind UmNotebook
My wired pc keeps discconecting from internet
Check for wire loose connection and then any time setting for your dhcp connection. If they are ok check your network connectivity do as follows.
Startup
run
type cmd
at the prompt type ping <your router ip address> -t
kepp watching the reply
use your computer as normally and check when it gets disconnect by watching above
may be some corrupted program send packets in an un usual rate (it can be virus/trojan) so the router blocks those port and your computer disconnect from the network.
Rather from all the above change the PCI Network adapter replace with a new network card.
Hothawk
Jul 15, 2008 | MSI Wireless-G RG54G3 Router
MSI wireless 802.11 LAN network connection not connecting
i don't know how should i connect to the internet with wireless in msi cr400 laptop!
May 05, 2008 | MSI : MP54G Wiress 802.11g Mini PCI Card...
Wireless connection
You should be able to reset the router.look on the back and see if there is a small, paper clip size, hole. Reset it back to default and try to reconnect.
Feb 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless connection
Chk if you are able to ping the router ( Start - Run - cmd - ping ip address of the router  ) . IF you can do this when you are wireless, you will know if your card is communicating with the router.
Alternatively, carry your laptop to any hot spot to chk if its the wireless card in your laptop or your router thats causing the trouble. Atleast you can isolate teh issue with this.
- Ranjit
ranjit@supportminds.com
Oct 27, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
MSI L730 Notebook Logo
97 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
