Question about SanDisk Sansa m230 MP3 Player
Powers down automatically
OK so Iturn on my mp3 play and it goes to the menu for about 1 second then it just powers it's self down. I've alreay reformatted it. It stays on when connect to the computer says (connected MTP) and yes I also tried new batteries :) anyone know how to fix this?...
  • Black_belt Feb 15, 2008
    how do I update the firmware?
  • Anonymous Mar 06, 2008
    how do you do that?
  • 758 Answers
Have you tried to update the firmware on the device..that would help..
Posted on Feb 15, 2008
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
Tip
How to put your ipod into disk mode and restore your ipod.
  1. Switch hold button to on then off.
  2. Hold down the menu and center buttons (select button) simutaneously until Ipod powers off.
  3. Immediately after Ipod powers down, hold the play and center buttons simultaneously.
  4. Ipod should say "OK to disconnect" or "Disk Mode"
  5. Plug ipod into computer and restore via itunes.
Congratulations! You just learned how to restore your ipod by putting it into itunes.
For more information check out http://repair-scratched-ipods.blogspot.com and www.huskyipodrepair.com
on May 05, 2010 | Apple iPod MA446LL/A MP3 Player
Powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Help!
To the op, you might need to switch it back to MSC mode from MTP mode. You might not be able to play the DRM protected music in MSC mode, but you'll be able to access all the rest.  1. With the unit on and not attached to a computer, press the Power/Menu Button briefly once or twice so the menu is shown.
2. Scroll down to Settings then press the OK button (round shaped, centrally located) to enter the submenu, next scroll down to the USB option and press the OK button to enter its submenu, highlight MSC, then press the OK button. After the MSC option is enabled, hold down the power/menu button until the unit shuts itself off. Now plug it back into the computer.
(Now you should be able to find some files to delete. Enter any folders/directories if necessary to find files to delete.)
Unless you have bought and downloaded to your unit protected music from online music stores, you might find it more useful to keep the MSC setting instead of going back to the MTP setting.
To the second poster, you likely downloaded a scam file.  It's sometimes disguised as an mp3 file but it's really likely to be a wma file that has web links that automatically execute when played in Windows Media Player.  Your mp3 player errors when accessing it. Just delete the suspect file(s).
Otherwise you could reformat it or maybe upgrade the firmware. Right-click its icon in My Compter for a popup that allows a format.  Use FAT32.
Sep 01, 2008 | SanDisk Sansa m230 MP3 Player
Plays until track 14 the it powers down and searchs and starts back at 1
If you plug it in your computer go to my computer then ilo (h:) it will show you all you misc then you find the song and deletle it
Mar 30, 2008 | iLO (2 GB) MP3 Player
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
Coby MP-C582 Will not turn on
Check on the side of the player and make sure it is not locked that was why ours would not turn on. Once I unlocked it worked fine
Dec 24, 2007 | Coby MP-C582 MP3 Player
Sansa isn't showing my files, shows up as 0 files.
I looked inside, and to my surprise (having opened other MP3 Players) there was a small watch battery that obviously powers the saving of settings.
So in the next day or two I will be changing this battery to see if it does indeed power those setting for changing thing like:
MTP -> MSC (which on Auto goes straight to MTP)
Finalizing Updates
Nov 27, 2007 | SanDisk Sansa m240 MP3 Player
Delete or reset a wrong firmware file for IVO- m600 mp3 Player (Rockchip)
This is how to get into update mode,
All you do is this,
1) Switch the player OFF using the main on/off switch.
2) Hold down the "MENU" or the "PLAY" button and keep it held down.(try the other buttons if these dont work)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the button.
5) You should be now in "ROCK USB" upgrade mode
6) Then just start ConsumerUpdate and upload your firmware.
Nov 18, 2007 | Audio Players & Recorders
SanDisk Sansa m230 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
