Question about Canon i9100 InkJet Photo Printer
Printer problem I have a Canon i9100 printer that, after going too far with cleaning the print head and getting a "damaged printhead" message, bought two new print heads. I tried both of them, but cannot get it to print the red. I do not get any error message, and it prints all other colors perfectly, just not red. Please help
  • lgurns May 13, 2008
    I had already tried that, and it didn't make a difference. I have since then bought another i9100. Thanks for your suggestion.
    Linda
  • Canon Master
  • 5,568 Answers
It may not be the case, but the nozzles are controlled by electronic signals and the common line for red may be defective.
If you cannot see any traces of red ink on the printhead surface and blotting (not WIPING) it with a hard paper towel produces little or no red on the paper, it is likely not getting any input from the control circuitry any more.
You can try GENTLY cleaning the electrical contacts (not the printing surface itself) on both the printhead and carriage with a cleaned pencil eraser or a Q-tip (look for lost fibers though)dampened with alcohol.
Unfortunately, if you can't restore it, the labor cost of having it repaired will probably be prohibitive.
Posted on May 09, 2008
When I turn it on I get an error message wrong printhead installed install correct printhead
hi. try to pull out the print head and clean the contact in the rear side . and reinstall it. if problem persist print head may be damaged
Mar 23, 2016 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
How do I clean and refurbish my old i9100
I doubt the waste tank is full, as the wide carriage printer can hold much more. As for cleaning, be very careful. I ruined 2 printheads for my using "magic" cleaner. Must have soaked the flexible traces together or apart. All I get is the bad head signal now..
Jul 15, 2012 | Canon i9100 InkJet Photo Printer
Printhead check nozzles on my Canon Lp-17 and the head is realy damaged, but can print still. Every time when I print I get this message and printer doesn't want to print. How Can I ignore this print with...
can you please tell me the exact message wich IPF reports.
i.e. "change left printhead"
You can also contact me on emma.servis@gmail.com, for troubleshooting manual.
Regards!
Aug 19, 2010 | Office Equipment & Supplies
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon i9100: colors printing incorrectly
I've had the Canon i9100 since 2003 and have excellent photo printing results. In 2009 it started playing up and I'd gt some banding. More recently, black didn't want to print. It was as though the black ink in the print head got dry some days.
April 2010 - The colours started printing strange and I bought a brand new print head and installed it. Only takes a minute. Still had an issue with photo printing. Black and white was excellent but colours weren't true.
Found advice online to try cleaning the print head to print head carrier electrical contacts by rubbing them with a rubber eraser.
I did that and now I'm getting perfect colour photo prints again.
I had been thinking about buying a new A3+ printer but this is old printer is now working as good as new.
Nov 16, 2009 | Canon i9100 InkJet Photo Printer
I have an 8-year old Canon i9100, and have just installed my third brand new Print Head. It worked fine for one month, then the black started fading and then just stopped printing. All the other colors...
It is probably a bad purge assembly, when it doesn't clean or prime the printhead properly you have the problems you are describing. There are 2 sections in the purge assembly, one cleans color and the other cleans the black. Sounds like the black pump is worn out. The part runs around $30.00
Jun 29, 2009 | Canon i9100 InkJet Photo Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
User manual
Hi.
You can follow this link to download you usernanual by going in here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=8738#DownloadDetailAct
Cheers.
Jun 14, 2008 | Canon i9100 InkJet Photo Printer
Canon i9100 InkJet Photo Printer Logo
104 people viewed this question
old marine
old marine
