Question about Dishwashers
Frigidaire Dishwasher FDB956RBC0
I just replaced the latch assembly on my Frigidaire dishwasher, now, it does not start. The green lights for the desired cycle work, however when you press the start button, nothing happens. A few seconds after pressing the start button, the green light goes off. Any suggestions?
  • JohnCollins Feb 13, 2008
    The plastic handle broke.
  • robert samples May 11, 2010
    why did you replace the door latch
  • 4 Answers
I successfully replaced the broken handle for my ELECTROLUX 24" Built-In DISHWASHER Model FDB956RB.
Try to check to make sure you reassembled all the parts and wire connectors properly.
Other than the broken handle, did you have other problems prior to replacing the handle/latch?
Posted on Nov 28, 2009
I have just gotten this same model and I am having a lot of problems...I can select a cycle, but can only get it to start if I set it for delay start. It does not seem to be cleaning any dishes either.
Posted on Sep 20, 2008
Did you ever get it to work. I have the same model and I have just ordered a new latch to replace the broken one. Anything I should watch out for? Any tips?
Posted on Jul 14, 2008
    President:
  • 1,314 Answers
Try opening the door and closing it to see if that clears the green light
Posted on Feb 13, 2008
Start button not working
Good Morning Friend, thank you for your post!
I see that your Frigidaire dishwasher has power but will not start a cycle. Let's try resetting your dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Best regards! - Z
May 18, 2014 | Frigidaire Dishwashers
Frigidaire fdr251rjs
The cycle timer could have failed
Oct 11, 2013 | Frigidaire Dishwashers
Dishwasher's green clean light is on, it will not restart and there is some standing water on the bottom.
Good Morning Emma, thank you for your post!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly, pump or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 25, 2013 | Frigidaire 24 in. FDB1050RE Built-in...
4yr old Frigidaire, green flashing ER light and red flashing washing/drying and red flashing clean/S. model# PLD 4555RFC3. Also green flashing china/crystal and red flashing rinse/low, start/delay doesn't...
Good Afternoon Sandra, thank you for your question!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 21, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I have frigidaire dishwasher model # FFBD2411NS. It stopped working as if it had no power. I switched the breaker swith to shut if of then tut on. After that the lights above the "high temp wash" and "heat...
Hello Marcus, since you have already reset the dishwasher, confirm that the door is properly latched and try selecting a cycle. If resetting the power did not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance. I hope this information proves to be helpful in some way.
Aug 04, 2013 | Frigidaire FFBD2411NS
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
529 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
