Question about LG KG800 Cellular Phone
People cannot hear me on their end, i can hear them
My wife has a KG800. When she calls me, she can hear me, but all i hear is static. The mute button is NOT on. any ideas?
Honey I found you! I was looking up problems for my phone, saw this question and didn't realize it was you. This is so frusterating!
Posted on Feb 13, 2008
Is there a mute button I can use while on the phone
yes when you make a call hit the menu button and select mute and visa versa and when the call is taking place you can hit the left soft key button to mute hope this was helpful:)
Sep 15, 2009 | Samsung BlackJack II Smartphone
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Static in audio output, even when mute button is pressed you can hear static in the background sometimes. The static is not always present continuously.
that can be a tuff fix , you gota tap
around the tuner mod and the auido
with a back end of a screw driver
I like to use a wooden back scracher.
bad solder joint , may be in the H.V.
also.
just a thought
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Plantronics cs50 head set with lifter has STATIC
Try a system reset:
1.  Lift the headset off of the charging cradle, but make sure the headset is turned off.  It will be off if the green light on the front of the base is not lit.  If it's not, push the call answer button once to turn it off.
2.  Push the call answer button and the mute button at the same time and hold them down.  The mute button is the black little wheel at the top of the headset.  Use the tip of your finger to push it straight down and hold it while holding the call answer button.  A green light on the headset will flash for 2 series of flashes.  Wait until the end of the second series then let go of both buttons.
3.  Put the headset back on the charging cradle and wait 30 seconds.  Lift it back up and try to use it.  If this doesn't work, repeat one more time and then disconnect the power from the base and plug it back in.
Apr 24, 2009 | Plantronics CS50 Wireless Headset
Put Phone on Mute while on conference call
The button for handsfree is the same button for Mute.
So when you are on the handsfree call, press the handsfree button again and the call is muted on your side.
To talk again, press the handsfree button to un-mute the call, then press it again to mute your call.
To hang up press the orange RLS button.
Apr 22, 2009 | NorStar Meridian M7310 Phone
Is there a mute option while I am on a call?
The mute button is the top right button, it's a clear colored button. When it's lit and orange it's muted.
Jan 19, 2009 | Mitel 5212 IP Phone
Person I call can't hear me
make sure you haven't hit your mute button somehow. This may be also in your menu que. These problems are really easy or really messed up. If it isn't the mute problem then there is probably a problem with the speaker mike. See if you can take it for exchange if this is it cause it isn't worth fixing$$$
Jan 18, 2009 | Sony Ericsson w580i Cellular Phone
Blue tooth not transmitting to caller
Did you check that you didn't by mistake activate mute? Also, check that there is nothing obstructing the microphone hole on the headset.
If it is indeed on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 08, 2008 | Motorola Mobility H500 Wireless Headset
T-629 Background Static/They can't hear me
You had a bad speaker and need to be replaced
Dec 04, 2007 | Samsung SGH-t629 Cellular Phone
LG KG800 Cellular Phone Logo
76 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
