No sound there is no sound coming from the computer.all sound settings are proper.all speakers rightly fixed.which drivers to download for windows xp,i think the drivers probably deleated when i had formatted the computer due to virus attack.wat to do?
  • 983 Answers
Check whether the audio driver is installed or not by going to control panel >system >device manager>audio devices...
if it is not installed then you must download from net or you upgrade to service pack 2 most of all drivers are there in sp2 as it has got very good driver database...
i would have given you the link to download the drivers but you didnt mention which sound board you are using ....
no problem you just do as i say
1.goto google and give the keyword as
" your motherboard or sound board name followed by audio drivers for windows xp for download" to search
2. then u will get the links just go in to that and download it..
if the same problem persists after installing the drivers also then there might be problem in speakers may be there is loose contact or may the speakers are not connected to the audio jack in cpu or the speaker is not powered on or the capacitor inside the speaker is gone...
please rate the solution.....
Posted on Feb 13, 2008
1. check the plag point &conection of the speaker to ur pc.check & instold the media controlar devices from proper sound device driver from your mather broad driver cd.after complition of the diver re start ur pc.it will be solved. thanks.
2.realtek ac' 97 audio driver
3 realtek HD audio diver.
What is solution speaker not working acer 5610
Solution is to download the AUDIO drivers, AND install them.
Don't know what Operating System you are using. This is required.
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=535
Three audio (Sound) drivers listed. Which one do you need?
Let's look. Click on each one, one at a time, and see what each one is for...................
First one -> Audio Driver - Realtek - 5.10.0.5273 - 24.2MB
After you click on it;
It states -> Audio_RealTek_5.10.0.5273_XPx86.zip
XP tells you it's for Windows XP
x86 tells you it is for a 32-bit operating system.
So it is for Windows XP 32-bit
Second one -> Audio Driver - Realtek - 6.0.1.5334 - 30.7MB
It states -> Audio_Realtek_6.0.1.5334_Vistax86.zip
Vista tells you it is for Windows Vista
It is for Windows Vista 32-bit.
Third one -> Realtek - 5.10.0.5273 - 24.3MB
It states -> Audio_RealTek_5.10.0.5273_MCE.zip
MCE = Media Center Edition
It is for Windows Media Center Edition, and that is a 32-bit O/S.
http://en.wikipedia.org/wiki/Windows_Media_Center
Now.................using the above information, it should be easy for you to determine what Audio Driver that is listed, is the one you need.
I'm going to use Windows XP for an example;
1) Make SURE there is a Green dot in the small circle, to the left of Save File.
If not; left-click in the small empty circle, to the left of - Save File.
Now go below, and click on OK.
2) A small download window will come up.
Allow the file to FULLY download, then DOUBLE-click right on the file name.
3) Another larger small window will come up. Go to the Left side, and click on - Extract all files.
4) At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
(DON'T change anything. Windows knows where to put it.
Just click on Next, Next, and Finish)
5) In the last small window DOUBLE-click on the file name.
If a Microsoft 'Squawk Box' comes up ignore it. Click on Yes, or OK.
If another small box comes up click on - Run.
[It is a ZIP file. A Zip file is a compressed file. It is used to send large amounts of information more easily. (Compressed)
You need to un-compress it, or 'un-zip' it.
This is what you are doing ]
When you are finished, if it doesn't ask you to restart your computer, DO SO.
(Windows XP: Click on Start > Turn Off Computer > Restart)
Close all windows, go back to your desktop screen, and restart your computer.
Also;
If the Volume icon is no longer down in the system tray;
Windows XP example;
Click on Start > Control Panel.
Click on Sounds, Speech, and Audio Devices
Click on Sounds and Audio Devices (Bottom right)
In the small window, and under the small blue subheading -
Device volume.............
Make sure there is a Green checkmark in the small square box -
Place volume icon in the taskbar.
If not; left-click on the small empty square to the left of -
Now go to the bottom right, and click on - Apply.
Then go to the bottom left, and click on - OK
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 03, 2013 | Acer Aspire 5610-4648 Notebook
Theres no audio sound drivers on my sound card
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check:
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer:
if you dont have a motherboard disk you will need to download the sound drivers
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://www.boxdrivers.com
using this link you will be able select your drivers
hope this helps
Aug 02, 2011 | HP Sound Card
No sound in my presario c300,please help me to find sound divice
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
if you dont have a motherboard disc you will have to download the drivers
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
Realtek AC
Jun 27, 2011 | Compaq Creative Sound Blaster PCI 128...
My computer can't detect my speakers MS-710 so, i think that i have to update and download the program for this one but, i can't found it. please, i need help!
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers
hope this helps
Realtek AC
Jun 22, 2011 | AOpen Speakers: MS-710 Pro Computer...
Sony Viao speakers model pcav-sp2 will not function properly on my new windows 7 HP Desktop, any suggestions.
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question or exclamation mark ! ? or red x right click to re-install drivers
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
May 27, 2011 | Sony DRIVER Computer Speakers
Need to find drivers for Juster SP-221 speakers (Windows XP). Thank you!
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
May 23, 2011 | Juster SP-225 Computer Speakers
My speakers work but no sound comes out. What can I do? I can't remember if I had to download something to make them work when I bought them. Is there a free download so I can get them working...
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
SoundMax Integrated Digital Audio Driver v hope this helps
May 16, 2011 | Cyber Acoustics CA-3090 Computer Speakers
I can not hear any volume through my computer speakers
heres a checklist
1) check the power cable of the speakers
2) check whether you have connected the speakers in right hole in your computer
3) check whether your have installed the proper drivers for your sound card
Nov 15, 2008 | HP Computers & Internet
No sound on my computer.
Check the BIOS settings in your computer to see if the sound was turned off.
Jun 13, 2008 | E-Machines eMachines Desktop PC
My right speaker does not work
My left speaker didn't work, I described how I fixed it here: http://users.tpg.com.au/malydog/fixits/logitechx230.htm
Jul 11, 2007 | Logitech X-230 Computer Speakers
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
