Question about Kitchen Ranges
GE XL44 gas range...door is registreing as locked when it si not
The oven door is registering as locked when it is not, therefore I can not turn on my oven to bake or broil....Help please!!!!
  • 5 more comments
  • whitneymco Feb 13, 2008
    The latch seems to move back and forth normally but on the screen it says the door is locked...anyway to just unlock the door completely so I can turn on the oven???
    I am not exactly sure what the lock motor is.....
  • whitneymco Feb 15, 2008
    It is a GE XL44 JGBP27 GEN1WG
    Is is free standing
    yes, that is in the front of the oven that you slide back and forth...
    and please dont apologize
  • Anonymous Sep 21, 2008
    My Ge oven door is saying it's locked up it's open! It's a GE XL 44 freestanding gas/convection rangethe model # is JGB910WEC4WW
  • Huntivy3 Jan 13, 2009
    the door is registered lock, when the door is not lock,i cant bake,broil in the oven.
  • robert samples May 11, 2010
    look to see if the latch for the lock motor is extended
    President:
  • 1,314 Answers
Try cancel if that doesnt do it try unplugging it for three mins
Posted on Feb 14, 2008
  • 2 more comments
  • robert samples Feb 14, 2008
    you have a brand and model numberwhat kind of oven is this wall oven freestanding
  • robert samples Feb 15, 2008
    is this a wall oven
    sorry for the questions but im trying to help does you model have a hand latch to lock the door
    does you top raise up it looks like you will need to get to the latch assembly and check the micro switch assembly that tells the eoc or clock that the door is locked it may be bad or stuck the second option would be to get to the back of the range and see if one of the wires is marked dr and un plug it third is lock the door start self clean then cancel
Display on stove showes all 88888's. Try turning off power to reset no good???
Posted on Aug 16, 2009
Cannot do anything but self=clean
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. More than likely your thermostat or oven control has been damaged and needs to be replaced. I would replace the temperature sensor as well
Apr 26, 2012 | Kenmore Kitchen Ranges
Top oven control panel malfunction. While broiling then switching to bake, door began to lock, I open door before it could complete lock, now "door locked" keeps flashing & I can't...
Hi, One thing you can try is turn off and pull out plug. If you can't get at plug turn off breaker down on pannel for 1 hour and them turn back on. if that does not fix it call repair man. pc board maybe at fault.
Jun 11, 2011 | Kenmore 41389 Electric Double Oven
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
I can't get oven to work on broil or bake; only self-cleaning.
Hello
Welcome to Fixya
My name is Huum,
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 21, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Broiling
it really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Jan 05, 2008 | Equipex PZ-330 Electric Single Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
757 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
