Question about Samsung ML 2010 Laser Printer
Big ink lines on paper
As i am printing I get Lines on my printed page. Most I clean the printer or what I have to do?
  • Maarten Leeters Feb 15, 2008
    everything is good with my printer. There is nothing broke down
  • Anonymous Mar 13, 2008
    how do you clean the drum?
    Sergeant:
  • Samsung Expert
  • 406 Answers
See the drum of the printer is having any lines crack or the surface damaged. may be it requires Drum to be replaced.
Best Regards
rafique
Posted on Feb 14, 2008
3 Suggested Answers
  • 67 Answers
SOURCE: printed pages have white lines
Adjust the properties of your print mode the default is normal change it to best. the printing speed will change but the print quality will be good.
Posted on Apr 27, 2009
CW Oly
  • 240 Answers
SOURCE: Smudged printing. Ink cartridge just replaced.
This is a laser printer and does not have a print head to be cleaned. Fortunately it does have a laser cartridge that can easily be replaced and solve all of your problems : ) The replacement cartridge is a HP Q2613A or the high capacity HP Q2613X. Your local Cartridge World should have a high quality refilled cartridge that will treat you very well and save you money.
Posted on Jan 19, 2010
Missing lines of print
hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Feb 17, 2012 | Dell 924 All-in-One InkJet Printer
Printed pages have blank lines every three or so lines.
Hi
It might be clogged ink or ink dries up. If the ink is new try to rub the print nozzle in a plain paper with rubbing alcohol until ink flows and run the print nozzle cleaning for 2 times and then try to print again. Regards
Jun 28, 2011 | Dell 926 All-In-One InkJet Printer
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
When I print blue horizontal lines appear or being printed as wel
Do the cartridges ride on the printing carriage, or do they plug in somewhere else in the machine and have hoses that run the ink to the print head? If they ride on the printing carriage and the cartridge is new, there could be a short in the printer and it needs repair. Check if there's ink smeared on the print head or part of the printer. Generously clean the print heads with lots of paper towels and rubbing alcohol. If that doesn't work, to see if it's an issue with computer, print a test page from the printer, but don't send the print job from the computer. You need a print job generated from inside the printer itself. Not every printer can do this, but try pressing paper feed, holding down paper feed and power, or holding down cancel and power. If the blue lines disappear then but they didn't when you cleaned the heads, it's a software issue.
Sep 17, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Prints only the top half of some lines.
Take the offending cartridge out and get a piece of tissue paper on your finger. Gently run the print head of the cartridge over the tissue paper. You shold see full lines of ink coming out. If not, the cartridge is out. If you see a full line of ink, reinsert the cartridge and do a clean cartridge from the tools menu
This should work
May 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Oct 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
Samsung ML 2010 Laser Printer Logo
160 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
