Question about Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA 32
Hi experts,
Really hoping you can help me out here guys.
My Hotpoint Aquarius WMA 32 doesnt seem to be taking in enough water to wash properly and the detergent drawer is full of water.
Can you help me?
Jason
  • Anonymous Mar 29, 2014
    keeps stopping on prewash
HOT POINT MACHINE END LIGHT NOT GOING OUT AND FINAL SPIN NOT WORKING
Posted on Nov 10, 2012
  • 958 Answers
Please check the outlet hose of the detergent drawer. it could be clogged with soap.
Posted on Feb 13, 2008
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
Jul 20, 2012 | Hotpoint Aquarius WMA56 Front Load Washer
Wash machine pump doesnt work
Hiya,
some machines have a filter at the front of the machine it will be right down the bottom behind the trim this trim normally just pulls to open & if so you will see a small circle if you unscrew that some water will come out & if blocked will have some stuff in that you can remove,
Hope this helps
Apr 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
Dec 19, 2008 | Hotpoint WMA48 Front Load Washer
Vibration problems
hiya
it could be a number of problems which are very common on the entire wma range.
1, drum bearings are really poor in these.
2, concrete block tapping, sometimes the bracket n the drums snap.
3, motor bracket snapped causing tapping.
i've found the plastic drums seem to be quite weak on the wma range to be honest so will more than likely be one of the above.
hope this helps
Jul 09, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA32 Front Load Washer Logo
499 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
