Question about Maytag Atlantis MAV9750A Top Load Washer
Maytag Atlantis washing machine
Actually the model # is MAV9600, approx. 6 years old; machine does not cycle from wash to drain to rinse to drain to spin automatically - I have to stop it and turn the dial to the point where this would happen (sort of like manually setting the stops and starts!)  Would this be a problem with the timer?
  • Anonymous Apr 06, 2008
    my mav7200 will go to wash to drain but will not rinse.
    I have tried to let the machine do its own thing by waiting it out
    but it won't do anything.
    Genius:
  • 1,554 Answers
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Posted on Feb 13, 2008
  • prem mathew Jan 09, 2014
    The mechanical timer has a very small motor attached to it. In most cases it is this small motor which is 'shot'. It could save you a pile if you just check this out and replace it. Easily available at spares, thru the net
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
May 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washing machine will not drain
your water pump may be jammed with a sock or something..its in the bottom of the machine
Nov 15, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV9750A Top Load Washer Logo
272 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
