Question about LG CED 8083B CD-RW Burner
JUMPER SETTINGS HOW CAN I SET MY CED-8083B JUMPER SETTINGS TO SLAVE?
  • LG Master
  • 13,433 Answers
The settings are pretty much universal, This comes from memory:
there are 6 pins
s m c
l
So you connect the first 2 pins. shown as .l.
If my memory is incorrect then try the middle one
if that doesnt work try the last possible combo.
trial and error my friend :) You can do it.
Posted on Feb 13, 2008
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
I have a LG CD-R?RW Drive CED-8080B/CED-8083B that has outdated software and reads burn process failed (power calibration error). I,m a beginner - don't know what this means. Need new drive? Update...
Sounds like you need to either update the firmware on the drive, or the drive is malfunctioning physically.
I'd just buy a new drive. Those things are very cheap now a days. Don't waste your time trying to fix it unless you can find an easy fix.
Feb 05, 2010 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Slave Jumper Position
ok......it is easy to do such, just place the jumper on the first : and enter the system setup them test if it is on slave if not repeat the same for all the ::::: untill you get the slave and cable select.
Sep 08, 2009 | LG (CED-8080B) CD-RW Burner
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
New CD R/RW drive will not let XP Boot
hi,
on the back of the new drive usually is a set of tiny pin jumpers, and a diagram for it on the drive, you might have to switch the pin jumper to "cs" cable select or "slave" usually master is for the hard drive. If that didnt do it then while the computer is booting hit f-8 or maybe f-9 and get into your bios area, search for boot sequence and study the area in there and see if your drives listed, try and change the config there so your hard drive(c) boots first, then usually your new drive. hopefully one of those ideas gets ya going, good luck
J
Jul 21, 2009 | LG CED 8083B CD-RW Burner
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
All of a sudden my computer lost contact with CD and DVD it sees them but will not load drivers. this is on a LG CD RW CED - 8083B and a Compac DVD - 115.
Go to start and right click on My computer then properties/device manager. Go to DVD/CD ROM and right click and select uninstall.
Reboot your system and windows will locate it and reinstall it.
Do this one drive at a time.
Mar 15, 2009 | LG CED 8083B CD-RW Burner
LG CED 8083B CD-RW Burner Logo
475 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
