Question about Hitachi 50SBX70B 50" Rear Projection Television
Intermittent video dim video usually on turn on then gets normal after a few minutes,but then goes dim again on channel change. ,
  • John Leonard Feb 13, 2008
    the crt's are very dim when the video is dim, and very bright when video is normal
    could you give me the comb filter removable board location or board number thank you
    Champion:
  • 206 Answers
There is a problem with a video processing board on this set, to repair this usaly means replacing up to 30 capacitors on this board and they are all surface mounted a very fragile, bust bet on this one is to take it in to the shop
Posted on Feb 13, 2008
  • Mike Owens
    Mike Owens Feb 13, 2008
    Yep ..... All video signal run thru what is called the 3YD/C Comb filter, this is a removable and most the times a repairable board, it sits on the signal board, however the ability to remove and replace all the defective capacitor usaly fall way beyond the scope of the backyard Tv repair guy. And being as I see this set is now 11 years old if it gets messed up you most likly will not be able to find a replacment
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
Feb 01, 2016 | Samsung HP-S5053 50 In. Plasma HDTV
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Flashing inst cluster
THE PARKING ASSIST MODULE ENABLES THE RIGHT SIDE OF THE INSTRUMENT CLUSTER
Apr 25, 2013 | 2004 Lincoln Town Car
Video turn off and audio works fine
There could be several things going on. I would seriously recommend you get a diagnoses on the set. But the first thing I would do is when the video goes away, dim the lights in the room and shine a bright light on the panel. If you see a faint image on the screen, you have a back light circuit fault. If you see nothing while shining the light on the panel, you have a fault in your video circuit which could be due to overheating on main board or t-con. Again with so many possibilities at hand, I would get a professional diagnoses.
Nov 24, 2012 | Televison & Video
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
VIDEO PROBLEM SAMSUNG LN46A630 I have a SAMSUNG LN46A630, after turn on the TV around two hours the screen goes black - the video disappear, some time the video come again the sound doesn't go, you can...
The Tuner signal board have intermittent problems.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish Tuner signal board for the replacement.
Oct 16, 2010 | Samsung LN46A630 LCD TV
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
My Dell Inspiron 1521 keeps going dim every few minutes
This is usually an inverter or lamp issue both of which you could do yourself if you felt comfortable delving inside your laptop.
It is not usually an expensive repair and parts are available from a large variety of sources but EBAY is a good bet.
If you don't feel comfortable then a good local tech shop will be able to handle it.
Either way If one of those components is failing it is usually better to replace BOTH as they are connected.
If you found this useul pleae click
Aug 15, 2009 | Dell Computers & Internet
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
